Results 1 to 10 of 15
Thread: Glass has come out of the runner....
    Regular Member danBoy's Avatar
    Jun 2006
    Northampton
    Default Glass has come out of the runner....
    I have an issue where my n/s rear door glass seems to come off the regulator....
    How does the glass attach to the regulator so I can fix this problem, I rarely use the rear windows but it just bugs me lol so I want to fix it
    Regular Member poves's Avatar
    lancashire
    There should be a plastic bung clip in the hole in the glass.
    This locks the glass to the plastic section of the mechanism.
    If there is no clip in the hole in the glass it's probably in the bottom of the door.
    Jun 2006
    Northampton
    Quote Originally Posted by poves View Post
    I'll have a look then as I've the door all stripped out till its fixed.
    lancashire
    It's hard to see behind the mechanism , but there is a round hole in the bottom of the glass , when you drop the window down , the clip locks into the tabs on the mechanism.
    Not sure if you can see what I mean , but you can remove the bar and plastic triangle section in the corner of the door ( this is held by a few torx head screws ) and then the glass will come out of the door completely , then put glass back , then put bar back in - in that order
    Jun 2006
    Northampton
    Yea I saw the hole in the glass, will have to dig around the door to see what I can find
    Jun 2006
    Northampton
    Well I found a round black plastic thingy in the bottom of the door, went to fit it and dropped it in the door but its vanished but there was no where for it to hide lol
    Devon
    77 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Quote Originally Posted by danBoy View Post
    Sods law mate bet its wedged in some where hiding coward
    lancashire
    If you do find it - it splits in two pieces , if you prize it with a screwdriver , then one section either side of the glass and lock it together.
    I'm pretty sure you will be able to get a new clip from vx .
    Jun 2006
    Northampton
    Does anyone know how the clip is meant to fit?? as I strangely found a bag of new clips hidden in my room from when I was gonna do the electric window conversion
    lancashire
    As I said above , the round clip splits into two pieces if you prize it apart with a screwdriver.
    Then you put one half either side of the glass and lock them together through the hole.
    Then you simply click the glass downwards and it locks onto the plastic tabs on the mechanism.
    P.S - they may be already split if there new , so you would need 2 halves if you see what I mean .
  1. Forum runner help
    By marc vectra sri in forum General Chat
    Last Post: 24th September 2012, 18:13
  2. Forum Runner
    By spennny in forum The 'Off Topic' room
    Last Post: 8th May 2012, 22:24
  3. Non Runner Sri DTI
    By dunning2008 in forum Engine & Drivetrain
    Last Post: 9th February 2009, 20:55
