Results 1 to 10 of 11
Thread: Help with CDR2005
    Apr 2009
    Derby
    Default Help with CDR2005
    Just purchased a 2003 Vectra 1.8LS and the radio was in safe mode. I tried entering the security code from hand book but this did not work. Pulled unit out to check serial number and code matched, this was OK. Now I have refitted radio, it shows 7 SAFE and will not let me enter any codes. Has anyone any idea's? Thanks for your time.
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    the code is written on the carpass!!
    Apr 2009
    Derby
    Hi, As I said I have the 4 number security code, thats not the problem, I cant enter one now!
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    think the 7 SAFE means you have 7 more tries but I don't know why you can't do it anymore.
    Sunny Dartmoor
    As Matt&Jemz said you have 7 more tries left,but each time you need the stereo turned on with the ignition off and wait until the dashes start to flash,i think you might have to wait over 10 minutes now,it gets longer each time you enter the wrong code,it does state it in the handbook,good luck......
    Apr 2009
    Derby
    Thanks for your help lads but it seems it's not a simple fix, radio removed for repair, thanks for your efforts.
    Regular Member SRI-150's Avatar
    Jun 2007
    Cheshire
    did you get this sorted i've got the same problem with the radio out of my mums corsa. 7 SAFE and it won't let me do anything
    Quote Originally Posted by SRI-150 View Post
    You need to leave the stereo and ignition (in position 1) switched on for 20 mins, then the display should show CODE for 3 seconds, then the remaining attempts, eg, "7 - - - - "
    Attempt 1 - wait 10 secs. (display show 10 SAFE)
    Attempt 2 - wait 10 secs. (display show 9 SAFE)
    Attempt 3 - wait 10 mins. (display show 8 SAFE)
    Attempt 4 - wait 20 mins. (display show 7 SAFE)
    Attempt 5 - wait 40 mins. (display show 6 SAFE)
    Attempt 6 - wait 80 mins. (1 hr 20 mins) (display show 5 SAFE)
    Attempt 7 - wait 160 mins. (2 hrs 40 mins) (display show 4 SAFE)
    Attempt 8 - wait 320 mins. (5 hrs 20 mins) (display show 3 SAFE)
    Attempt 9 - wait 640 mins. (10 hrs 40 mins) (display show 2 SAFE)
    Attempt 10 - time for the dustbin.
    Jun 2007
    Cheshire
    cheers dave i will go and try that now
    lanark
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    let us know how you get on mate cause you will need to wait 20 min before entering the code
  1. cdr2005
    By blackveccyC in forum Electrical & ICE (including SatNav)
    Last Post: 27th April 2011, 17:17
  2. Cdr2005
    By glenboy in forum Parts for sale
    Last Post: 22nd August 2009, 20:11
  3. Cdr2005
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 13:59
