Thread: sump plug rounded off/wrecked
    brum
    Default sump plug rounded off/wrecked
    hi after going to remove my sump bolt for its first service i noticed the torx insert screw bit (if you know what i meen) has been slightly rounded off and as i started to loosen it it was just getting worse. i have tried grips to remove it but to no avail.
    anyone got any tips or suggesgions on it as i dont want to pay a garage all that money to do a simple job.
    thanks in advance
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    2 things.
    Hammer
    Chisel
    Knock a notch radially in the outer edge, and then hit tangentially to loosen, applying some turn force with the torx bit will assist the intial crack.
    Then refit a new plug and O ring.
    Regular Member steve's Avatar
    Nov 2007
    Ashington, Northumberland
    You may be able to bang a bigger torx head in but remember you are going to need a new one and o ring before the old one comes out as if you get it out you are unlikely to get the torque needed to tighten it back up.
    Nov 2007
    beaten to it!
    brum
    ok yea i was thinking the chisl was the way forward, i have the o ring but not the plug looks like another trip to vaux tomorrow lol is this a regular occourance?
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Yes, the original factory fit is very tight.
    Nov 2007
    IIRC the newer vecs 55 onwards dont have torx inset they have an external hex for a spanner.
    Regular Member carpet's Avatar
    Jul 2006
    TENTERDEN KENT
    If the threads are identical it would be well worth the purchase of the newer type of sump nut. Then a good ring or socket would prevent this problem occuring again. Dont do the nut up to tight as it should only be torqued up to 14Nm /10 lbf lb if a 1.8 or 20/ 15 if a 1.9 oiler.
    brum
    sorted now lads i just tapped in a slightly bigger/ longer torx bit and hey presto, fitted a new plug mind and service now complete thanks
    Good result ................. well done m8 ..................
  1. Sump plug
    By shb1988 in forum Engine & Drivetrain
    Last Post: 23rd August 2012, 18:37
  2. Spark Plug & Sump Plug Torque setting - Z18XE Engine
    By wafoo in forum Engine & Drivetrain
    Last Post: 4th June 2012, 21:15
  3. Sump plug rounded off - Help
    By Barlow in forum Vectra C / Signum Car Chat
    Last Post: 1st April 2012, 15:11
  4. Rounded off sump plug... any ideas?
    By BigWilko in forum The 'Off Topic' room
    Last Post: 20th July 2010, 22:10
  5. rounded sump plug
    By baz2003uk in forum Vectra C / Signum Car Chat
    Last Post: 11th June 2007, 20:43
vectra c using hex sump plug www.vectra-c.com
