Results 1 to 10 of 11
Thread: 1.9 CDTi (120) - Normal Operating Temp?
    Regular Member vec1975's Avatar
    West Midlands
    Default 1.9 CDTi (120) - Normal Operating Temp?
    I have had my car since 2006 with 2700 miles on the clock. The normal operating temperature (except when it's minus temps) has always been approx 90 on the temp gauge.
    Just lately it never seems to go above 84ish. The fuel economy has not changed and the performance of the car hasn't changed, but just wondered if anyone might know what has caused this and if it is the start of a problem?
    Chris
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    My 150 usually runs at 85.
    Regular Member LJ sxi-nav's Avatar
    Winchester
    85-87 degrees on mine (120 CDTI)
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Mileage : 66000
    75 ish on my 150
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    85-87 on my 3.0
    75 or less on the 2.2DTi with a faulty thermostat
    West Midlands
    so anything between 75 & 90 could be classed as normal?
    Oct 2007
    estonia
    engine temp should be over 80 deg C. normal would be 85...95. 75 is too low. on some diesel with DPF the regeneration process is allowed to start just when engine coolant temp is 81 ... deg C. Below it the process will not start and soot will clog up the DPF.
    West Midlands
    maybe mine is ok then
    Lancashire
    Trim : XP1
    Mileage : 66000
    So no thaving a DPF its all good, running at 75 mine is nice and cool
    Regular Member xrken's Avatar
    northampton
    rolleyes
    75 to 90 120 bhp 06 plate
  1. normal cdti 150 temp??
    By elite_150 in forum Engine & Drivetrain
    Last Post: 6th June 2012, 08:57
  2. What is the normal running temp of 1.8 VVTi
    By Exclusive BV in forum Vectra C / Signum Car Chat
    Last Post: 8th December 2010, 18:47
  3. Whats the normal operating temp when moving?
    By devore in forum Vectra C / Signum Car Chat
    Last Post: 21st March 2010, 18:55
  4. Normal operating temperature?
    By runs4miles in forum Engine & Drivetrain
    Last Post: 28th April 2008, 20:54
  5. 'normal' coolant temp
    By Mike57 in forum Engine & Drivetrain
    Last Post: 9th July 2007, 20:27
normal temperature for vauxhall vectras
what is the running temp for a vectra 1.9
whats the operating temperature of a zafira b 1.9 cdti
vauxhall vectra running temperature
what temperature should Vauxhall zafira 1.9 cdti be
1.9cdti 110kw operating temperature
vectra 3.0 cdti how long to get to normal running temprature
vectra c 1.9 cdti normal temperature
normal temperature of vectra diesel
normal operating temperature 1.9 cdti
vectra c 1.9 tdci working temperature
1.9 cdti working temperature
xafira diesel temperature
normal coolant temperature of zafira
what us the normal temp for opel zafira
running temp.of vectra 1.9 sri diesel (150 bhp)
avarage running temperature for vauxhall H
opel zafita 1.9 cdti water temp
what is the average running temperature of a vectra
working temperature zafira b
cdti 120 temperature
normal temperature zafira 1.9
engine temperature 1.9 zafira
astra h 1.9 cdti normal coolant temperature
vauxhall zafira normal temperature
