Thread: Heating/climate control query
    Apr 2009
    Redcar
    Default Heating/climate control query
    I have just bought an 04 reg Signum Elite.
    It has climate control, which to be honest is a little OTT for me. Its a ****** pain to change setting and I would much prefer a basic set up with a heat dial, a dial to direct the vents, and fan speed control, + switch for air con etc
    Im curious as to whats involved in changing this. Can i just swap the control panels over or is it more complicated than that?
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    oooo if this works big word there IF ill do a deal with you your for mine!!
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Wont work.. that swap...
    All the motors, computer systems and valves etc are different mate, it's a no-go to retrofit anything that isn't already fitted form the factory...
    You'll get used to it, same as anything new in the car...
    Oct 2006
    Wellingborough
    the climate control is actually brilliant. pick a temperature you're comfortable in (21 or 22 degrees) set it on auto and leave it alone. cue thousands of miles of lovely driving. left alone you'll find it does do the right things.
    11 Post(s)
    Quote Originally Posted by Nosher View Post
    You have all that with climate. To manually adjust the fan speed, just turn the large centre dial.
    To adjust the heat, just turn the outer dial on the drivers side and note the temperature reading on the stereo display. If you want the passenger side to follow suit when you adjust the drivers side then press in the heat adjust dial.
    To direct the vents, push in the large centre dial and adjust via the simple menu. Similarly, if you don't want the AC on, then you can switch it off via the same menus. However, the thing with climate is to leave it switched on all year round. Your windows will never mist up. The temperature in the cabin will be more accurately maintained as well.
    Apr 2009
    Redcar
    Thanks for all your advice chaps
    Glasgow
    I spent a week in a new SRi and i hated the normal heating dials, when i got the GSi back it was like heaven no messing about.
  1. Climate control and GID
    By Ben_ in forum Electrical & ICE (including SatNav)
    Last Post: 5th October 2011, 19:30
  2. climate control
    Last Post: 10th August 2011, 09:34
  3. Heating temperature control not working - Full heating permanently
    By jratcliffe3 in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2010, 23:46
  4. Heating control
    By Alec in forum Electrical & ICE (including SatNav)
    Last Post: 19th May 2008, 20:37
  5. Heating control
    By Alec in forum Engine & Drivetrain
    Last Post: 19th March 2008, 08:17
astra j climate control swap to normal heater
how to set temperature on climate control astra sri 2010
setting up climate control vectra c
