Results 1 to 10 of 14
Thread: Rear control arm bushings
    Regular Member Ziggy's Avatar
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Default Rear control arm bushings
    Afternoon all,
    Looking for help again as always. I have been told i need to replace the above. My mechanic says that he thinks last time he tried to do it he had to get new rear control arms at £80 a time from VX (he is confirming this for me).
    Just thought i would ask you knowledgeable people what the situation is? Can i just replace the bushings? or do anyone other VX do a set of control arms?
    Thank you in advance
    Stephen
    Northampton, UK
    Are we talking about the "Rose" bushes that are on the control arms? The control arms about £60ish each from dealer, when I got mine they had the "Rose" bushes on them. I think you can get them separate thou... I've seen them on Ebay.
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    I will have to check. He just said the rear control arm bushings...
    Are they really called rose bushes?
    Northampton, UK
    Yep, they are pivot inside both ends of the control arms. No idea why they're called that though. Its a bit of a hassle to get the bushes off, thats why I just had the arms replaced.
    Look here LINKY
    And here LINKY
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    So, you can replace just the bush on the top links then???
    Northampton, UK
    I think so - HERE - is the tool for it
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Any difference depending on the engine \ spec?
    Northampton, UK
    Not that I know off. The control arms are the same the range over (I think!) its only the springs, dampers etc that may be different.
    West
    The rear upper control arms are the same part for all vectra -c's, signums, saab's & fiat tempera lol...
    You can get them from Andrew page's at half the cost of a dealer part.
    hth
    Leeds
    Vehicle : Saab
    Trim : 9-3 Vert
    Engine : 2.0
    Year : 2000
    Cheers all
    Much apreciated as always
  1. What kind of anti-roll bar bushings ???
    By Z80 in forum Suspension, Wheels & Brakes
    Last Post: 16th February 2013, 00:58
  2. Rear Lower control arm
    By cookie in forum Handling & Braking
    Last Post: 31st July 2012, 11:41
  3. Rear lower control arm
    By DHobbs in forum Suspension, Wheels & Brakes
    Last Post: 23rd May 2012, 07:27
  4. Help! rear bushings
    By NI-2.2SRI in forum Suspension, Wheels & Brakes
    Last Post: 26th September 2007, 23:54
  5. Radiator Bushings (Mounts)
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 23rd March 2007, 20:19
