Results 1 to 1 of 1
Thread: Engine and Gearbox
    Wondering lonely as a cloud
    26 Post(s)
    Vehicle : M5
    Trim : Nothing needs adding
    Engine : 5.0 V10
    Year : 07
    Mileage : 37000
    Default Engine and Gearbox
    All Models
    VX Coolant
    93170402
    VXR Air Intake Pipe
    9177099
    Pollen cabin filter
    93172299
    Charcoal cabin filter
    93172129
    All Petrol Models
    Lambda Sensor For Petrol Engine
    55353269 or 93180670 depending on VIN number as there was a change in MY2004
    2.0 Turbo models
    2.0 turbo engine cover "Vauxhall"
    55350449
    3.2 Models
    3.2 GSI Spark Plugs (Bosch)
    9195868
    3.2 Induction Control Unit/Actuators
    93173995 (RH), 93173996 (LH)
    93173993 (LH), 93173995 (RH)
    Diesel Models
    1.9CDTi
    Thermostat for 1.9 CDTI
    Thermostat, with housing z19dtl, z19dt: 55202510
    Thermostat, with housing (pratola serra) z19dth: 93179136
    3rd Injector Mod Kit
    93189918
    EGR blanking plates (Available from Fiat)
    Large one - 71751468
    Smaller One - 55225287
    Swirl Valve Replacement Parts List
    93191278 - Engine Timing Parts Kit
    55210201 - Inlet manifold
    55199915 - Bracket (Actuator)
    93179058 - Gasket
    55215031 - EGR Valve
    93181665 - Gasket
    93178885 - Gasket
    93170402 - Antifreeze
    Particulate filter pressure sensor
    55190617
    2.0/2.2DTI
    2.2 DTI Boost Hoses
    hose 1 - 9178636
    hose 2 - 9178635
    2.2 DTI Boost Sensor
    0281002437 (Manufacturers Part Number Bosch)
    2.2 DTi Auxilliary Belt
    55354681
    2.2dti oil filter
    9117321
    2.2dti sump plug
    90502556
    Air Conditioning Parts
    Compressor - 13171593
    Compressor Repair Kit - 93182415
    Condenser - 13114943
    'O'RING, 25.2MM OD. X 17.1MM, REFRIGERENT PIPE TO CONDENSER - 24436645
  1. gearbox and engine oil leak
    By humelis in forum Engine & Drivetrain
    Last Post: 2nd December 2011, 15:21
  2. engine and gearbox mounts
    By james walker in forum Vectra C / Signum Car Chat
    Last Post: 13th September 2011, 19:35
  3. New.recon engine and gearbox
    By PCOchap in forum Engine & Drivetrain
    Last Post: 3rd July 2011, 16:24
  4. Engine & Gearbox Mounting
    By redjohno in forum Engine & Drivetrain
    Last Post: 7th January 2011, 00:15
  5. Engine / Gearbox Mounts 2.2 DTI
    By MJL in forum Engine & Drivetrain
    Last Post: 20th October 2009, 12:43
sensor 55190617
