Thread: After market Blaupunkt
    Carnoustie
    Default After market Blaupunkt
    I have a Blaupunk memphis fitted in my vec full can bus! no steering controls and not ideal power control via the cig lighter feed! the place where I bought the unit do an adaptor bit its 100 quid
    can be found here http://www.bluespot.co.uk/install/show_model.asp?id=288
    just wondered if that money would be well spent, what would I gain apart from steering controls?
    Or would I best get a cd40 opera?
    cheers Ronnie
    Carnoustie
    Any input anyone?
    Kent
    Vehicle : Fiat
    Trim : Panda 100HP
    Engine : 1.4
    Year : 08
    Have a look for a Connects2 adapter,i had one in my half can-bus Vec,it worked better than blaupunkts own and it was only 30 quid.
    Carnoustie
    Quote Originally Posted by tyreman View Post
    thanks for that, will have a look
    cheers Ronnie
    Oct 2007
    Reading
    Vehicle : SAAB 93 Estate, Vectra C Estate
    Trim : LINEAR SE, Elite
    Engine : Z19DTH, Z22YH
    Year : 08,08
    Quote Originally Posted by ronnie63 View Post
    Power through the wiring loom, so radio is ignition controlled and will also operate independently of the ignition, i.e. will switch on with the ignition key out if required.
    Have one in mine yes it's expensive but it works well.
    Comes with the Vectra aerial adaptor which is £11.99 otherwise.
    Or if you don't want steering wheel controls but want proper ignition control get the Vauxhall Vectra wiring adaptor at the bottom of the page for £19.99, but you will loose the ability to reset the car clock as no steering wheel controls
    Carnoustie
    Quote Originally Posted by Inner Zone View Post
    good info there, thanks for that, just need to save up now
    cheers Ronnie
  1. Blaupunkt systems
    By Marky in forum Electrical & ICE (including SatNav)
    Last Post: 21st February 2008, 11:53
  2. Re: Blaupunkt 2620
    By ope126 in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2006, 13:39
  3. Blaupunkt Rabbit
    By 2ltrT in forum General Chat
    Last Post: 25th February 2006, 01:11
  4. Blaupunkt bonking
    By simonali in forum Comedy & Humour
    Last Post: 17th September 2005, 18:11
