Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Memory upgrade question.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Default Memory upgrade question.
    One for you computer guys out there. My laptop is running 1 256mb in one slot and the other is empty. I've just bought 2x 1 GB so a GB in each slot. My question is, when I take the single 256mb out, will I lose anything, programs, photos ect?
    Steve
    Full Member Big Sig's Avatar
    No you won't
    Can your laptop support the new memory?
    Birstall
    Vehicle : Exclusive
    Engine : 1.9
    no everything will be fine aslong as the laptop can support the high memory
    No you won't
    Quote Originally Posted by magpie27 View Post
    This may help you find if your laptop will be ok hth .........
    http://www.aememory.co.uk/
    or this one
    http://www.crucial.com/uk/store/drammemory.aspx
    Vehicle : SRi
    Mileage : 137000
    I just downloaded a tool from Crucial.com It scans your computer, tells you what you have, then tells you what you can put in. The 2 cost me £22 all in. I will post up the scan.
    Sounds like you had a good deal Mr Rush ...............
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Tadpole View Post
    Did the same scan on my work Dell Lappy and for the same 2x 1gb upgrade it would cost £90
    HERE you go, this is from my scan.
    Full Member Penfold101's Avatar
    If it only came with 256 I'd be surprised if it could take 1GB in each, but you never know...
    FYI, the memory is volatile stuff - ie unless there is a power supply to it it can't hold the data. A hard drive its the opposite, and is more permanent not requirting a permanent power source...
    Only other thing to check is the speeds of it dude - should be about 333MHz ish...
    It depends on the type of ram required, so now you should find the laptop works a lot quicker. I do a Disk Clean up at the end of every day & a Defrag about once a week hth ..........
  1. Sorry - another display upgrade question
    By Chris B in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2012, 13:51
  2. Rear brake upgrade question.
    By John LE in forum Handling & Braking
    Last Post: 9th August 2009, 20:55
  3. GID and Stereo upgrade question
    By redraptor_141 in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2009, 22:46
  4. bulb upgrade question
    By nph1 in forum Vectra C / Signum Car Chat
    Last Post: 19th May 2007, 18:23
  5. Another Light Upgrade Question
    By jka in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2005, 16:05
