Results 1 to 10 of 20
Thread: Swirl Valve
    Cambridgeshire
    Default Swirl Valve
    I guys can somebody do me a favour. I've been reading through some of the search threads about the swirl valves in the 150 and i'm now got myself worried, can comebody ease my concerns or point me in the right direction?
    I've been noticing that i have low power below 2000 revs. There will be low power then when the turbo kicks in it's away. (Now i'm lead to believe this is normal as this is where a diesel will get it's power from ?) Some of the threads i was reading through people are saying that it's the swirl valves etc... on their way out. Is this true? Or am i being daft?
    Lancashire
    Vehicle : Vectra SRi
    Trim : XP1
    Engine : 1.9 CDTi 150
    Mileage : 66000
    Yes and no, being a diesel it will be alot flatter off turbo than on, but it should still pull from about 1200rpm through to the turbo kicking in and beyond.
    Easiest way to check the swirls is to pop your engine cover off and have a look down the gap at the front of the inlet manifold, there is the swirl valve control bar, that should be attached to each of the four swirls (don't worry about this area being a bit gunked up).
    If that is ok, then it could be that your EGR/boost sensor needs cleaning.
    Hope this helps.
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    hello mate
    mine did the same when i first got it,
    no power then all of a sudden whoosh off it went
    took off egr valve completely full of kak (it had only done 18,000 miles)
    cleaned all that and boost sensor, completely differnet car now, power is steady and consistant through the range
    try it
    Cambridgeshire
    Cheers guys.
    I have checked the swirl valve rod/bar recently and it's still there/in place with a bit of gunk. (Is it worth trying to clean the gunky carefully?)
    I cleaned out my EGR valve not long ago, took it all apart as per How2 and it didn't make any difference that i could tell maybe i need a new one.
    Apr 2008
    Lincs
    Quote Originally Posted by parsco View Post
    Cheers guys.
    what about boost sensor ?
    Surrey
    I have a swirl valve stuck fault would this be a solenoid?
    Belfast
    No, it'll be the swirl valves stuck (oddly enough).
    Cambridgeshire
    Quote Originally Posted by Grimo72 View Post
    Where can i find this and does it need replacing or can i clean it?
    darlo
    took my car to vx today and they told me my swirl valve has gone and will cost £920 to fix but does any1 know that afta i pay all this money is there any chance than they will go agen
    Regular Member wanna veccy's Avatar
    Nov 2007
    telford,
    yes m8 they will go again but when no one knows, when i had mine replaced i asked the tech's that exact same question and they told me that there has been no update for the parts used so it will defo go again at some point.
  1. swirl valve
    By HARRY SRI in forum Engine & Drivetrain
    Last Post: 12th January 2011, 19:10
  2. Egr valve, swirl valve problems etc..
  3. oil and swirl valve
    By POAH in forum Engine & Drivetrain
    Last Post: 28th September 2010, 21:29
  4. Swirl Valve Rod ....
    By denzo in forum Vectra C / Signum Car Chat
    Last Post: 11th September 2008, 19:15
  5. Swirl Valve Q??
    By robdd1 in forum Vectra C / Signum Car Chat
    Last Post: 8th March 2008, 11:30
