Results 1 to 7 of 7
Thread: Bigger Cylinder Head.
    Apr 2009
    AMMANFORD
    Default Bigger Cylinder Head.
    I have a 1.8 engine,and was wondering if i can improve its performance by bolting on a 2.0/2.2 head.
    Or possibly having the 1.8 head bored out to either of the above.
    Would this work?
    I already have a large cone filter,aftermarket rear silencer,and a resistor chip on the airflow sensor.
    Or sell it and buy a 2.0 Turbo - easiest way of doing it dude...
    Regular Member mattolly86's Avatar
    oxfordshire
    in a word no, the engines will be different mate and you'll proably find the water jackets, oil feeds dont match up
    Apr 2009
    AMMANFORD
    Was just a thought.
    Would it be possible to have the haed bored out though.
    Or would it be better in the long run to get hold of a Z20NET engine and fit that instead.
    Save yourself the time and money and just buy a new car with the 2.0 Turbo in it mate - cheapest way of doing it and opens up all sorts of power options with BSR etc...
    Apr 2009
    AMMANFORD
    Thanks for the advice m8.Will have a brows for one now.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Mileage : 137000
    If you port the head of the newer Z GM lump the ECU throws a fit. Unless its in say an older Astra ot corsa which your lump is the newer ECU's wont allow that much tolerance, the only way round it is with a stand alone ECU, but that wont work as you wont be able to tie it in with the Canbus.
  1. Cylinder head
    By GCusdin in forum Engine & Drivetrain
    Last Post: 20th September 2012, 11:11
  2. is my Cylinder Head going
    By jinkie in forum Engine & Drivetrain
    Last Post: 4th January 2012, 09:25
  3. Cylinder Head
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 1st May 2008, 15:35
  4. Cylinder Head
    By Matt21385 in forum Engine & Drivetrain
    Last Post: 18th February 2008, 17:42
