Thread: Another front knocking issue.
    Regular Member Ben999's Avatar
    Milton keynes
    Default Another front knocking issue.
    I lowered the car yesterday. The new springs seem to be bedded fine but there is now an awful knocking noise over every little bump which is gradually getting worse.
    When i undid the drop links I did notice that the rubber seemed to be pretty much knackered. I havent had a problem with them until now. So I've ordered two new ones.
    Is it possible that the drop links were knackered and undoing them has caused them to pretty much fall apart? and would this likely be the cause of said knocking noise?
    Milton keynes
    bump.
    Milton keynes
    someone must know!
    Full Member spennny's Avatar
    Blantyre
    Hello mate, Yes i would have said, changed my drop links on other veccy, same issue you had and it cured it,
    Milton keynes
    Cheers Spenny. I shall give it a go when I get back from Cornwall. The vectra is having a rest in the garage as the missus insisted we took her car. Fuel economy or something like that!
    Milton keynes
    Changed the drop links. Still a knocking noise. It doesnt appear on every bump, and seems to be coming from the right hand side. Cant for the life of me work out what it is.
    Regular Member zazaszazas's Avatar
    Cumbria
    i've had the same problem when i fitted my Koni springs...but somehow the noise disappeared 10days later.No knocking noise since then. By the way i changed the links too
    wales
    changed my links and a r b yesterday cured the awfull squelching noise but while doing it i noticed the ball joint was cooked on drivers side must of been that making knocking noise as its still there
    Milton keynes
    Ive checked everything. Springs seated correctly. New drop links are fine and all bushes are fine. I'm not even sure that it is coming from the suspension. Could just be a coincidence.
    Regular Member signum03's Avatar
    worthing
    sounds like the anti roll bar bush to me, there about £2.50 from stealers, there are how 2s on fitting, also check torque on wish bones, you may aswell change both arb bushes at same time.
  1. Knocking from n/s front
    Last Post: 12th April 2012, 10:54
  2. knocking from front end
    By danny_n in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 14:40
  3. Knocking from the front
    By Derek Mc in forum Engine & Drivetrain
    Last Post: 26th March 2011, 23:13
  4. Knocking at front
    By NikNakNok in forum Engine & Drivetrain
    Last Post: 7th June 2010, 12:09
  5. Knocking Front O/S
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 19:40
