Thread: 2.0dti glow plug light
    Apr 2009
    manchester
    Default 2.0dti glow plug light
    should the glow plug light come on when i first start my 03 vectra 2.0dti in the morning,it is a pig to start and when it does i get a cloud of white smoke for a few seconds then its fine.the light only seems to come on when its really cold.
    Plymouth
    when i first start mine in the mornings the glow light is on for around 10 seconds.. it dodnt u sually come on again during the day... but after a few hours of leaving it its usually quicker to go out..
    Ive only started the car twice before the glowlight went out and i got white smoke and tons of stink!!!
    Apr 2009
    manchester
    does the light always come on in the morning regardless of temp as mine only lights when its really cold outside.
    Plymouth
    yeah no matter the temp (bearing in mind this is the hottest the mornings have been since ive owned the car)
    Apr 2009
    manchester
    thanks for that,does anyone know what could be causing this before i start shelling out cash, bad glowplugs,relay, its doing my head in.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by Diet1985 View Post
    same here.
    West
    Glow plug light does not come on unless the temp is around 5*c or has been overnight...
    The poor starting could be down to either an air leak in fuel system (leak off pipes or fuel filter housing) or it could also be due to lack of compression.
    What sort of mileage is your motor?
    My motor has just done 100k & has no starting probs at all with or without the glow plug light.
    hth
    Apr 2009
    manchester
    the cars done 56000 miles,it started running rough yesterday so i changed fuel filter which made no diference,undone all leak of pipes and plugged back in and misfire has gone but engine is surging on tickover, so i will get new leak off pipes and t pieces and see what happens after that.just hope its not injector seals that i have been told can also cause similar problems.thanks to all who have replyed.
  1. Veccy 2.0DTI glow plug caps
    By cyberbobdude in forum Engine & Drivetrain
    Last Post: 26th June 2012, 07:10
  2. Help needed!!! Glow plug lead removal 2.0dti
    By FLOB in forum Diesel Engine related
    Last Post: 17th March 2012, 18:24
  3. Glow plug light
    By mrpoochie01 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2012, 06:37
  4. No glow plug light
    By iasha in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2010, 18:14
  5. vectra c 2.0dti glow plug problem
    By barrymanalow87 in forum Engine & Drivetrain
    Last Post: 17th April 2009, 19:04
