Thread: Engine management light on after airbox mod
    Regular Member jsr645's Avatar
    Northants
    Default Engine management light on after airbox mod
    Hi,
    My Vectra is still smoking when first started for the day - even in the warm weather. Its been to the stealers and they can't diagnose the problem, but just recommended I monitor it. Anyway, after reading several threads on here, I decided that I'd do the air box mod and see if that helped as a starting point.
    I took the plug off the air sensor (I assume) so I could open the air box and disconnected the hose. I removed the air filter, hoovered out the air box, cleaned the filter, removed the additional plastic part in the box and reassembled the lot. Reconnected the plug and hose. Today, after starting the car for the 2nd time the engine management light stayed on and won't go out.
    Would unplugging the plug on the air box do this, or anything I did? How can this be reset without going to the dealers?
    Thanks,
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Did to turn on the ignition with the plug unplugged at any time, if so that's what will have tripped it. To clear it, just disconnect the battery for 20 mins HTH
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    hmm wen i done the same mod it never happened. mabey theres and underlying ossue with the AFM
    Northants
    Hi - No ignition was off entire time until everything was reconnected and put back together.
    Will disconnecting the battery do anything to the stereo/sat nav etc?
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by jsr645 View Post
    yeah you will have to enter the radio code.
    dont meen to insult your inteligence but did you put it back togethet the correct way, eg. the MAF. is the arrow pointing the way the airflow goes???
    Northants
    Right - all seems to be ok again now. Just checked the manual - not engine management it was the exhaust emissions light (quite appropriate considering the smoke problem!!!)
    Anyway, I disconnected the battery for about 5mins - then panicked as I didn't remember seeing any radio code for the CD/Nav system in the paperwork with the car - so ran to reconnect in the hope that it hadn't wiped its memory and needed the code within this time. Reconnected the battery, started car and the light went out and stereo/nav working ok.
    Few - panic over - thanks for everyones help!
    Northants
    Quote Originally Posted by mick 1986 View Post
    Thanks Mick 1986 - seems to be ok now and yeah double checked in case I was day dreaming when I put it back together and its all the right way and properly connected. Hopefully the light will stay out now!
    Vehicle : SRi
    Mileage : 137000
    Stereo will be ok if you have rollers not button on your steering wheel. You might need to reset your electric sunroof and windows though.
    By Shadrack in forum Vectra C / Signum Troubleshooting
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Engine management after airbox removal.
    By !tf in forum Vectra C / Signum Troubleshooting
    Last Post: 30th April 2011, 13:51
  4. No throttle, traction control light, engine management light
    By si260188 in forum Engine & Drivetrain
    Last Post: 9th May 2010, 21:45
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
