Results 1 to 10 of 13
Thread: Rear Brake Pads on a 1.8
    Stevenage, Hertfordshire
    Default Rear Brake Pads on a 1.8
    Just had the car serviced.
    (Full service including oil. filter, plugs, air,fuel and pollen filter, brake fluid change and rear brake pads £290.00)
    and the local garage (independant family owned) have done a superb job.
    But
    Rear Brake Pads at only 21,000 miles...fronts are showing only 25% worn.....seems a bit excessice, or do the vectra eat rear pads...Garage say the claipers are nice and free but the inner pads where gone
    Any thoughts.
    Car is standard trim running 205/55/16 on steel rims, mileage is low for a facelifted 2006 1.8 Life model 55 plate
    Full Member Big Sig's Avatar
    The rears do sometimes wear faster, its a trait
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep, the rears do tend to go first. The pads are very small compared to the fronts so take a bit more of a beating per square inch.
    Regular Member JagRigger's Avatar
    Norfolk
    Engine : 1.8 VVT
    Mileage : lots !
    My inners were down to metal at 26K
    Regular Member Smirnoff's Avatar
    Buckley N.Wales
    Quote Originally Posted by JagRigger View Post
    Yeah mine wore out at just 17k on the clock, think it maybe a good excuse for a brake conversion next year!!
    NORTH WALES
    Angry rear discs + pads at 19000mls
    Vectra 1.9TDi 150 new Jan 2008. offside rear inner pad down to metal at 19000mls - new discs and pads fitted
    Has anyone challenged Vauxhall as their specified service interval is 20,000?
    Its a max of 20k services, thats what they will probably tell you. Also it depends on how you drive ie on the brakes all the time down hill or changing down a gear or too etc. Just thinking of all their excuses. Driven hard they would probably only last 10k!
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Brakes aren't a routine service item to change. You change them when they're worn down.
    My rears went to 75K before they needed changing.
    NORTH WALES
    Default rear pads
    I had a 2.2 petrol NOV 2000 vectra before. It went 46k mls before changing any pads so I don't drive excessively hard.
    Have contacted Vauxhall via the net and they responded by phone very quickly [give credit where credit is due] but only to say they would look into it.
    I advised them I am not the only one experiencing the premature wearing out of rear brake pads [thanks to messages on this site]
    I advised them my view was
    service interval is incorrect
    or
    brake linings too thin [or too small in area as suggested below]
    or
    brake lining material was faulty or not of the quality required
    or
    the braking system design is inadequate
    Whatever the cause the braking system is not fit for purpose
    I await Vauxhall's response with interest.
    Vehicle : SRi
    Mileage : 137000
    Although my calipers were free I found a good clean of the slider bolt and some copper slip helped with even wear.
  1. Rear Brake Pads
    By tony-1977 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2011, 18:25
  2. rear brake pads
    By gdansk in forum Vectra C / Signum Car Chat
    Last Post: 8th July 2010, 08:21
  3. Rear Brake Pads
    By steve-wolves in forum Suspension, Wheels & Brakes
    Last Post: 17th August 2009, 14:18
  4. Rear Brake Pads
    By cp123 in forum Suspension, Wheels & Brakes
    Last Post: 24th May 2009, 13:15
  5. Rear Brake Pads
    By CHRISSMART41 in forum Suspension, Wheels & Brakes
    Last Post: 16th October 2007, 18:22
