Thread: Aerial base rubber
    Regular Member old cruiser's Avatar
    slough
    Default Aerial base rubber
    Just been washing the car and noticed the rubber base of aerial is starting to perish, is this the only seal preventing water ingress r is this just the cosmetic rubber? (sorry the photo is a bit poor)
    Cheers Pete
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Mine went on my last motor and I ended up with a puddle in the spare wheel well. About £35 for the base from VXL IIRC. Shouldn't be too hard to change.
    Glasgow
    Mine is on the road out aswell, i dont fancy the idea of pulling the head lining down though
    Regular Member scottrp's Avatar
    CREWE
    you could always do this mate makes it look so much better lol
    Seems to be a common fault Pete. I was told I could get just the base for but I have yet to check this out at the dealers hth .............
    slough
    That's always food for thought mate, however, I don't appear to have a leak here, so I'm guessing the main bit of rubber that's right underneath the base itself is probably intact, so will keep an eye on it and see what happens., as I don't fancy the idea of removing the headlining to gain access.
    Cheers Pete
  1. DAB Aerial Rubber base rubber seal
    Last Post: 19th November 2012, 15:57
vectra c aerial base rubber
vectra c aerial base seal
https:www.vectra-c.comforumshowthread.php79625-Aerial-base-rubber
vauxhall vectra aerial base rubber
vauxhall vectra c aerial seal
vectra ca aerial base
vectra c aerial removal
aerial rubber for a Vauxhall Vectra
vectra c signum antena removal
vauxhall vectra c aerial base
how to remove an arile on a Vectra C
vauxhall vectra aerial seal
vectra c sealing aerial.base
how to get to ariel base on vauxhall signum
vauxhall vectra 06 aerial base
how to remove vectra c aerial base
vectra c aerial base size
aerial removal vectra c
ariel base rubber vauxhall vectra
vectra c hatchback aerial base seal
vectra c aerial rubber seal
