Results 1 to 10 of 15
Thread: Bulb Failure Light While Towing
    Regular Member cerbrious's Avatar
    Apr 2008
    Wigan
    Default Bulb Failure Light While Towing
    fitted genuine vaux towbar and twin elecs with the towing module fitted and activated by lookers in warrington (read as overpriced and incompatent) they openly told me they didnt really know what to program now whenever i connect a trailer or light board the dash light for bulb faliure illuminates but no message on screen and all bulbs working 100%. little reluctant to go back to them incase it gets worse anyone got any ideas
    or if anyone in the area has tech2 or a similar system and could check if they've done it right i'll happily pay for their time
    regards
    Gareth
    Take it back to them and get them to do their job properly, the bunch of muppets. Refuse to take it back till it's all working properly as it should, and contact Vauxhall Customer Services if there's any more problems with them...
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    i dont know what type of tow bar i have but when i connect the trailer mine does the same, however when i turn the lights on the bulb goes out so no problem.
    hope you get it sorted.
    Regular Member darby's Avatar
    www.NinjaUK.com
    I connected mine by splicing directly to the existing wires for the tail lights. No bulb failure warning at all!
    Regular Member GoldenWonder's Avatar
    Durham
    I've just had a right carry on with my bulb warning light. For days its flicked on an off even though every bulb was working OK.
    Decided to check every bulb individually today to make sure no dirty connections etc and all OK.
    Switched the lights on and suddenly both of the number plate lights have blown their bulbs!
    So maybe you've just got a bulb on the 'borderline' of going! I don't know how this system works but maybe a bulb that is working, but about to fail causes it to flag it on the display.
    Quote Originally Posted by GoldenWonder View Post
    As I understand it that's exactly how it works hth ...........
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Check the plugs for loose/dirty connectors. I had this with my trailer. Its a really sensitive system
    Apr 2009
    england
    bulb warning system measures resistance in circuit which is why it is so sensitive
    Full Member sulten's Avatar
    Øvre Årdal, Norway
    Check trailer socket for correct conection, when the car have check control you have to conect right and left tail light individual.
    It's an option in programing to check foglight and reverse light, if trailer dont have it, it must be turned off.
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
    Apr 2008
    Wigan
    problem sorted thanks sulten the ****** thing was looking for a reverse light so ive sorted that problem on my caravan with no reverse light by using the reverse light feed by the leisure battery (yellow wire on 12s input) and using a tail light bulb connected to it and back to earth. kinda means i now have a nice illuminated leisure battery when i select reverse. but NO annoying light on the dash
    does anyone know the resistance of a tail light bulb was thinking i could maybe make a kinda override plug for pulling other trailers by getting a spare 12s plug and connecting up the reverse light and earth pins with the correct value resistor anyone know if this will work??
  1. Bulb failure light on dash - always on.
    By Dal5band in forum Bodywork & Interior
    Last Post: 15th December 2011, 14:23
  2. bulb failure warning light on dash
    By bigbill94 in forum Electrical & ICE (including SatNav)
    Last Post: 9th June 2010, 19:35
  3. bulb failure light
    By paulzvectra in forum Vectra C / Signum Car Chat
    Last Post: 15th July 2009, 20:03
  4. bulb failure light
    By billyyoung in forum Vectra C / Signum Car Chat
    Last Post: 4th November 2007, 16:10
why does bulb fault always show in vectra
