Results 1 to 10 of 13
Thread: Limp mode & Emissions light
    Apr 2009
    Durham
    Unhappy Limp mode & Emissions light
    I have a 2.0DTI 04 reg, about 6 months ago I changed the air filter (Non GM) not sure if it just a coinsidence but after this the emissions light (engine shaped light in right corner of dash) came on, took it to garage to get fault codes and it showed MAF related fault. Changed the MAF meter and was still having problems, the emissions light went out after codes were reset but now on a hot day the car goes into limp mode when accelerating, it goes off when i turn off ignition and start again whilst still moving! Found a split in the turbo intercooler hose so after replacing this i thought everything would be hunky dory but its not to be!!!
    Still flat as a fart when car EML is on, if the light is left on too long it then swaps to emissions light and same problem with limp mode. I am at my wits end now, any ideas folks????
    I also need a new front window so comtemplating driving the car into it, kill 2 birds with 1 stone - new window, new car!!!!
    Full Member
    Bristol
    The boost pressure sencor will cause that problem. Remove it an give it a clean.
    Apr 2009
    Durham
    hi, thanks for the reply. Don't mean to sound thick but where is the boost pressure sensor??? lol
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Lift your engine cover off , and at the front of the engine you will see a manifold leading off to the right , just before the hose connection there is a sensor at the back of the manifold , that is your boost sensor . see pic enclosed
    and still loving it
    Engine : 2.0DTi
    Mileage : 73350
    Also have a look at thread,s and how 2,s concerning cleaning egr valve,s and fixing faults with the vacuum system , both very common faults with the dti engine,s.
    and still loving it
    Apr 2009
    Durham
    Hi thanks for you advice, I removed the egr valve and gave that a good clean today, i also checked all of the hoses for splits/damage (none found). At forst the car was driving perfect and the emissions light went out on its own but again when the outside temp got to around 14C the car/spanner light came on and the engine went into limp mode.
    I noticed the boost sensor when working on car today, how do i clean it? it doesnt look like i can get into it very easy or clean it
    Engine : 2.0DTi
    Mileage : 73350
    Just remove it from the housing , 1 screw and pull only retained by rubber ring , and spray with carb cleaner and adjitate with very small paint brush (carefull it can be easily damaged ) that should be sufficent .
    what set up have you got for your vacuum solenoids ? is it two on bulkhesd above radiator and one between engine and battery or two on bulkhead and one by maf filter? . the reason i ask is that the former setup is known to cause problem,s because the solenoid overheats being to close to the engine
    and still loving it
    Apr 2009
    Durham
    Talking
    Quote Originally Posted by bobssignum View Post
    Hi, i can only see 2 vacuum pumps, 1 between maf and air filter housing and 1 at front near battery. i have removed the boost sensor and gave it a clean, the egr valve is spotless and im still having problems with limp mode, i will not give up though!!
    Bought some carb cleaner to spray in inlet manifold (which by the way is full of gunk) and also some injector cleaner to put thru the system. ordered a genuine GM air filter incase it has something to do with that too.
    Any other ideas?
    thanks
    Regular Member garvey's Avatar
    Co Durham
    Thats interesting my runs lovely for about 10/15mins then spanner light comes on my 2 are above radiator
    Engine : 2.0DTi
    Mileage : 73350
    I am not saying this is gospel because i have been proved wrong in the past , but check your actuattor solenoid,s for suction .
    when working normally they only pull about 0.6 bar which is just detectable with a wet finger usually.
    If nothing can be detected then check backwards down the vacuum line to the next connection , this is incase the line is blocked , rare but has been known if nothing at diaframs ,then suspect actuattor solenoid,s are faulty , have someone rev the engine for you while you test solenoid,s its a lot easier
    and still loving it
  1. Spanner Light but no Limp Mode
    By GazVXLINE170 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 13:07
  2. Limp mode, Emissions Light and poor performance
    By jonny_rubber in forum Vectra C / Signum Troubleshooting
    Last Post: 1st October 2009, 19:09
  3. Exhaust Emissions Light Limp home mode
    By corby-boy in forum Engine & Drivetrain
    Last Post: 5th August 2009, 20:53
  4. Limp mode, Emmision light on
    By sirnapper in forum Engine & Drivetrain
    Last Post: 25th May 2009, 01:43
  5. spanner light on 2.2 dti and goes in to limp mode
    By thelad in forum Engine & Drivetrain
    Last Post: 14th March 2008, 21:48
Tags for this Thread
