Thread: Aircon issue or not?
    UK
    Default Aircon issue or not?
    Took my 2006 vectra elite to kwickfit today to get the aircon gassed as its not been very cold. They did not top up the gas as they said the pump was only working intermitantly, they said the clutch engages and then disengages. They used some lube or similar to try and free it off, did'nt charge me and said to come back next week and they'd see if its any better.
    Does this sound like my pump is on its way out or could it be doing this because the gas is low, i've heard before that the pump can switch of to protect itself if the gas is low???
    Any Ideas
    Full Member Big Sig's Avatar
    Its supposed to switch on and off according to the load its under from the cooling system as its a magnetic clutch. Too much or too little gas could make it do it. What was the air temp from the vents?
    tech 2 can read the gas pressure in the system too.
    UK
    They didn't tell me the air temp from the vents, it is cool but nowhere near as cold as last summer. When it's on auto it takes along time to get down to temp with the vents blowing hard.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Possibly a bad connection on the top of the air con clutch?
    UK
    Is there a plug/connector on it that I ca check? If so where is it situated?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    The compressor is on the left hand side of the engine at the front. It'll have two silver pipes coming from it. There shoud be a multi-plug there too. The dti has it on the top not sure about others
  1. Aircon problems - Not working, if anything air gets hotter turning on aircon???
    By Coupe2T in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2012, 10:13
  2. Aircon
    By Sean-2.2Direct in forum Bodywork & Interior
    Last Post: 27th November 2008, 19:04
  3. aircon issue
    By Darryl2.2DTI in forum Bodywork & Interior
    Last Post: 31st August 2008, 19:00
  4. Change aircon to auto-aircon?
    By um20 in forum Electrical & ICE (including SatNav)
    Last Post: 20th March 2007, 22:12
insignia 2.0 cdti aircon issues
