Thread: New DMF
    Planet Earth
    Default New DMF
    Decided to bite the bullet and replace the DMF due to a previous concern with vibration and a worn out thrust bearing.
    I dont ride the clutch, drive easy etc - how many miles should this new DMF now last me?
    Current car is a 2006 Facelift 1.9CDTi SRi with 40k on the clock.
    Regular Member xrken's Avatar
    northampton
    Question
    yup join the club the same here but mine has done 78k and is a 1.9 cdti design 120 bhp 06 plate
    Planet Earth
    Quote Originally Posted by HAPPYTREE View Post
    Any ideas fella's?
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Apparently starting the car with the clutch depressed should help make it last bud
    Leicester
    If you have a new clutch and flywheel and based on the fact that we all should know how to treat the car's, you should be set up for as long as you have the car.
    preston
    The dmf in my car has done over 100k miles, but mainly motorway, its the stop start / hard acceleration that ******s 'em up so i suspect a dmf in a 120 cdti would probably last longer than one in a 150 cdti
    Regular Member s0501291's Avatar
    Warrington
    can anybody tell me what the symptoms are of a worn DMF? any noises or vibrations? in neutral or in gear?
    Pete
    Planet Earth
    Quote Originally Posted by Maverick View Post
    Cool. Not had my car long so I guess the previous owner wasnt as caring as me.
    That said, I have the new kit fitted now so I'll be going easy and the DMF will have a better life with me!
    Leicester
    Quote Originally Posted by bygumlad View Post
    Not Strictly true as the 120 will have a DMF to suit 120PS and the 150 will have a DMF to suit 150PS.
    So they should last as well for each car.
