Results 1 to 10 of 23
Thread: Strange noise when starting 2.2.....
    Regular Member bobby-tupper's Avatar
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Default Strange noise when starting 2.2.....
    this is starting to happen abit too often for my liking,when you go to start it up after it has been stood there is a really nasty metal on metal sound for about 2/3 seconds which then stops,you can then turn off the engine and restart 4 or 5 times before its heard again the engine sounds normal when its revved up and driven. (yes ive checked the oil) could it be the starter motor?
    its a 2.2 sri petrol 03 reg
    LEEDS, W.YORKS
    Vehicle : 07 Estate
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Like this or more metallic?
    Full Member Big Sig's Avatar
    That sounds like tappets being drained of oil
    Vehicle : SRi
    Mileage : 137000
    The vid is of my Car. Have been advised that it could be a sticky lifter. 10w40 oil helps it a little as is thicker, but it tends to do it not on a cold engine, not on a hot engine but on a warm one, say you have been shopping and come back to the car.
    Sticky lifter/ tappet..... its all the same
    Vehicle : SRi
    Mileage : 137000
    Yep, I wondered why you mentioned it, then noticed I put an ! instead of a 1 for 10w40 now edited.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    sticking lifter or lazy tappett try and get some FORTE engine flush through work (trade only) its spot on it cures same problem on fords CVH engine or pop round to mine and i will have a listen or could be sticking starter motor
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by big tee View Post
    Mine's had flush through it a couple of times, sorts it for the first few days, then its back, although that was with Wynn's.
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    hi rushy... try and get hold of the FORTE stuff its superb i use there diesel treatment on M.O.T failures fill the fuel filter with it start car and rev 9 times out of 10 they pass
  1. Need help with strange noise
    By tony-1977 in forum Vectra C / Signum Troubleshooting
    Last Post: 6th January 2013, 18:04
  2. Strange noise
    By vectra craig in forum Suspension, Wheels & Brakes
    Last Post: 13th May 2012, 23:27
  3. Strange Starting issue and Exhaust emission/gases light on
    By njsb14 in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd September 2010, 20:14
  4. Strange noise???
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 13th May 2010, 14:41
  5. strange starting
    By Morephun in forum Engine & Drivetrain
    Last Post: 27th August 2009, 16:33
