Thread: help with wires
    Regular Member simon5800's Avatar
    May 2007
    derbyshire
    Default help with wires
    hopefully someone will be able to help me with this one, at the front of the bumper where the air temp sensor is there is a loom connector, 4 or 5 wires go into the block but only 2 wires come out going to the sensor, so the question is what are the other ones for
    thanks
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    think they are for the front fog lights
    May 2007
    derbyshire
    thought so, on the other side i have a conector and the only thing i can think off is for the fog lights. the electrition at the garage said the wiring was there for them just needed tech2'ing
    Engine : 2.2 Direct
    Do you have a pic of the connectors? because then ill take of my bumper (tomorrow) as i have a few bits to do anyway... to compare them..
    Apr 2009
    Chester
    The last one i did i had to fit the foglamps and switch, then replace the Underhood Electrical Centre (fuse box) then tech 2 it all together!
    May 2007
    derbyshire
    Quote Originally Posted by kenp View Post
    cheers, dont have one at the min but can get one later, the one i am on about is hidden behind the lower grill on the bumper, seems to be a small conector type thing, sure you will know what im on about when you see it i hope
    Engine : 2.2 Direct
    ive just taken a pic of mine.. didnt have the bumper off.. (i do have front foglights) dont know why mine have that many wires.... (maby prepared for something i dont know)
  1. Routing wires
    By JonnyB_UK in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2012, 21:42
  2. 2.0 DTI MAP sensor wires
    By grabos in forum Engine & Drivetrain
    Last Post: 17th July 2011, 09:30
  3. What are these wires?
    By Ziggy in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2011, 14:18
  4. best place to run wires?
    By mattster87 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd December 2009, 20:14
  5. what are these two wires for?
    By JammyBStard in forum Electrical & ICE (including SatNav)
    Last Post: 22nd March 2008, 19:25
