View Poll Results: Which would you choose?
Voters
26. You may not vote on this poll
  • Nex 4pot 324mm kit
    20 76.92%
  • VXR single pot 345mm kit
    6 23.08%
Results 1 to 10 of 15
Thread: Which would you have?
    Regular Member darko2301's Avatar
    Croatia
    Default Which would you have?
    I desperately need new brakes because the standard ones simply aren't adequate for this engine (especially now when it's chipped)
    I'm trying to decide which kit to go for but I simply cant..
    I would go for either VXR single piston 345mm kit or Nex 4 piston 324mm brakes..
    Now, as many of you probably haven't heard of Nex, I guess that you would go for VXR..
    Nex brakes are being used by neobrothers and a lot of other tuners, and their saab which won nurburgring and some other races has them fitted..
    some astra vxr owners have them fitted too and they say it's a massive improvement over OEM 4mm bigger (328) disc..
    they don't look bad and I think that they might offer better brake force than VXR because there isn't that large difference in diameter, and Nex brakes have 4 pistons which gives a lot more pressure to discs and stopps more effective.. they are also much less likely to fade which is important on so heavy car like vectra. the discs are floating design, more resistant to heat than OEM ones so that's their another advantage
    prices are similar, so let's put question this way:
    If both were free and you had right to choose one, which would you choose?
    I think I would try the 4pot solution, what about you?
    All comments are appreciated.
    btw, here are the pics
    I thought you were not doing any more mods or is this for safety .............
    Croatia
    erm, safety before everything
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    the 4 pot set looks wicked, but what size rims are you one at the moment
    Croatia
    19" mate, but they would fit behind 17" too
    Regular Member Matt&Jemz's Avatar
    CORNWALL
    gotta be the nex ones for me
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    4 Pots anyday!!! If there a proven product. Foud this discussion on them.....
    http://www.vxronline.co.uk/forum/sho...nex+big+brakes
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    The NEX ones look realy great i must say... (i cant afford them any way... as here s kit about 1300£ http://webshop.nordicturbo.dk/produc...&MenuItemID=69) but looks a bit different to the one you have found.
    Somerset
    i own a vxr and would choose the NEX's all day mate.. what price can you get them for and do they do brackets for the my06 onwards as i think they changed that year?
    Croatia
    Quote Originally Posted by CHRISK View Post
    i have read that whole topic and people talk mostly good stuff about them..
    they even look good fitted to a car..
