Results 1 to 3 of 3
Thread: Crank Shaft Oil Seal !!!! PLEASE HELP!
    Regular Member s0501291's Avatar
    Warrington
    Hi All
    I have noticed for a little while now a rattle/nocking comming from the engine, mainly on tickover. I thought it sounded like just somthing generally catching due to the vibrations of the engine at tickover e.g. the filler bottle neck of the screen wash or the plastic cover on the engine. Anyhoo, its got a bit worse/louder and I had a look today to see if I could see anything obvious and noticed that the pulley on the end of the crank shaft (aux belt end of the engine) seems to be WOBBLING! a bit. not a HUGE amount but all the other pulleys run true and straight, and when you look side on at the crank pulley you can see a bit of wobble..... ALSO, oil is running down from behind the pulley and down the sump. Im thinking its the oil seal gone, but unsure if this would acount for the wobbling??? Any advice would be apreciated
    Pete
    Oh, I should have also mentioned that when you rev the engine just off idle, the noise seems to go, not sure if it just gets drowned out, or the increased speed of the engine kind of cancels out the low frequency vibrations
    Pete
    Northampton, UK
    Might help by saying what year model, engine etc you have... someone might have had this issue already
    Warrington
    Hi
    Sorry, good point,lol.. I have a 2003 LS 1.8 petrol
  1. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  2. P0016 Cam/Crank Shaft
    By sri150 in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:44
  3. 2.0T oil leak, poss crank seal or sump seal?
    By mann3210 in forum Engine & Drivetrain
    Last Post: 3rd March 2012, 11:11
  4. Y20 DTH Snapped Crank Shaft
    By keithtinman in forum Engine & Drivetrain
    Last Post: 15th July 2011, 15:48
  5. Crank Shaft Pulley???
    By Stephen S in forum Engine & Drivetrain
    Last Post: 1st September 2010, 20:27
