Results 1 to 10 of 14
Thread: Crank Shaft Pulley???
    Stockton on Tees
    Default Crank Shaft Pulley???
    Had my crankshaft pulley replaced today and the belt for £150 all in. Was told by Vauxhall this was a common fault. Mines a 2.0 DTi 54 plate with 46,000 miles. Anyone else had this problem??
    Steve
    Regular Member garvey's Avatar
    Co Durham
    Mine went last week engine had done about 40,000. but my other 2 engines had done over 180,000 each and never changed
    Regular Member s0501291's Avatar
    Warrington
    Hi
    I've just posted a new thread about a vibration/oil seal problem im having from my crank shaft pulley,, can I just ask,, when you say yours "went" do you mean it dropped off? or was it off balance? any symptoms you had? just trying to see if it could be related to my problem
    Pete
    Co Durham
    I had no warning it just broke away and flew down the road
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    when i worked for a vauxhall parts department i used to sell a few of these pulleys
    Stockton on Tees
    Thanks for replies. The pulley was really loose, and the belt had come off. The only warning i got was the air con not working and the car over heating. AA man said the pulley must of moved and the belt slipped off. No mechanical warning wot so ever. Glews Garage at Goole said it was a common fault but the pulley ain't cheap. I paid £105 plus vat for the pulley and belt.
    Bristol
    Vehicle : CDTI 150
    £105 for a belt and pulley is good, Vx charge £172.00 for a pulley and bolt (yes that is bolt and not belt).
    Stockton on Tees
    The parts i priced up where from Andrew Pages and + VAT. These where not Vaux parts but probably made in the same place just with out the GM stamp!! The spares shop i usually use will be cheaper than this as i get a 10% discount on anythink. Unfortunately i wasn't near home :-(
    Apr 2009
    dundee
    Default Crank Shaft pulley
    Quote Originally Posted by Stephen S View Post
    Steve
    Mine has just had the crank shaft pulley done again today, was 235 altogether, this is the second time its failed, i had it replaced about a year ago under service agreement, i have a 2.0d hti 54 vectra. the guy in the garage states that this is a common fault on the Y20DTH engine and vx always have a stock of these parts.
    Barry
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    235! Who was that from?
  1. crank shaft sensor
    By dr1v3r in forum Electrical & ICE (including SatNav)
    Last Post: 3rd October 2012, 19:54
  2. P0016 Cam/Crank Shaft
    By sri150 in forum Engine & Drivetrain
    Last Post: 13th March 2012, 13:44
  3. Y20 DTH Snapped Crank Shaft
    By keithtinman in forum Engine & Drivetrain
    Last Post: 15th July 2011, 15:48
  4. Crank Shaft Oil Seal !!!! PLEASE HELP!
    By s0501291 in forum Engine & Drivetrain
    Last Post: 24th April 2009, 19:53
  5. crank shaft pulley nut seized 2.2 dti
    By steviedigdig in forum Engine & Drivetrain
    Last Post: 27th April 2008, 21:27
