Results 1 to 9 of 9
Thread: 2.0T idle problem
    Jan 2009
    Nottinghamshire
    Default 2.0T idle problem
    At what speed should a 2.0T idle? do owners find that there idle fluctuates 100 revs either way? Does your 2.0T drop to about 500 revs when you press the clutch when about to stop before the revs recover to about 800? Sometimes when idleing at traffic lights/junction the revs will also drop to 500 before recovering, this happens fairly often when stationary, any ideas what the problem is? Thanks
    Oct 2006
    Waterloo, Liverpool
    26 Post(s)
    Trim : SRI VX-LINE NAV
    Engine : 1.5T (165)
    Year : 2018
    Mileage : 37000
    Should idle at about 700 revs. Slightly higher if Air Conditioning on. Revs will rise above idle as high as 1000 on start up but should quickly settle to 700. At least that's what my 2.0T does. Never noticed any fluctuation when idling or when depressing the clutch.
    Mine idles at around 750, bit higher if the Climate Control has caused the compressor to fire up. Never noticed any dip in revs with depressing the clutch either.
    Oct 2007
    estonia
    The 2,0T idle fluctuation and possible sudden engine stop from idle could be caused by throttle body. Try cleaning the air channels. If that doesnt help then you`ll probably need a new TB.
    Jan 2009
    Nottinghamshire
    Well its in the dealers, they have tried to update the ECU but the installation locked half way through. The car now wont start and a new ECU is on order. Is this kind of thing common?
    Err no, definitely not common!
    Regular Member n_hudson's Avatar
    Mar 2008
    Northampton, UK
    New ECU? Are they paying for that???
    Regular Member pogo's Avatar
    Feb 2006
    Growing old disgracefully!
    7 Post(s)
    Vehicle : Vauxhall
    Trim : Astra gtc vxr
    Engine : 2.0 turbo
    never noticed this prob on mine but it does cut out sometimes
    Jan 2009
    Nottinghamshire
    Well, new ecu fitted, tech 2 wont even communicate with the new ecu now but will still with old ecu is place. Sounds like the new ECU is faulrty but the dealer insists its a wiring problem, common sense states that it cant be but im just about giving up.
  1. idle problem
    By speedfreeride@yahoo in forum Engine & Drivetrain
    Last Post: 6th June 2009, 19:15
  2. idle problem
    Last Post: 3rd June 2009, 00:30
  3. 2.2 16v - Idle Problem
    By SNODDY70 in forum Engine & Drivetrain
    Last Post: 24th March 2009, 09:29
  4. Idle problem
    By Spelly in forum Engine & Drivetrain
    Last Post: 20th January 2009, 00:08
  5. Idle problem?
    By dawn brown in forum Engine & Drivetrain
    Last Post: 16th January 2008, 01:50
vectra c pre heat
