Results 1 to 10 of 13
Thread: 1 weak rear light..
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Default 1 weak rear light..
    Hi guys
    hope you have some help for me... i noticed sometime ago that 1 of the rear lights was very weak (like ½ the light of normal).. well then ill just change the lot.. didnt notice if it was Okay.. as i havnt really been out driving while dark (or just didnt look)
    But then yesterday, i noticed it was the same.. 1 weak rear light (the same light...) any suggestions.
    WGAF#5
    Quote Originally Posted by kenp View Post
    Hi guys
    have you tried swapping the bulbs just to rule them out??
    Engine : 2.2 Direct
    yes first time i changede them all.. and last night i swaped 2 of them, no change...
    WGAF#5
    unplug the rear light units and swap em over on the connectors will rule out if its a wiring issue or resistance on the circuit board to the supply
    Engine : 2.2 Direct
    that would be a bit difficult.. as its a estate.. other wise i need to know what wires to swap in the REC...
    WGAF#5
    they still come out -remove the COMPLETE lamp assembly - and then plug it in on the opposite side they dont need to be fixed into place to try but it would rule out the matter of resistance on one of the PCB's
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    it sounds like it is a resistance issue, but as it was in both light units i would say its in the connector block that plugs into the back of the light cluster.
    try spraying the plugs with WD40/GT85 or something similar and reconnect.
    Engine : 2.2 Direct
    not its not a spcifik bulp thats the problem.. its the one specifik lamp... (its the rear light on the right side of the tailgate on the estate (seen from the back)
    but cant do it now... its still way to much light... need a dark room to see
    Flintshire
    I have had the same problem on the estate always that same side.Is it related to how they use a single filiment bulb for both stop and tail. how does this work anyway?
    Engine : 2.2 Direct
    hummm okay....
    well they only send like 3,5 volt normaly until you brake then they send 12 volt to the bulp..
  1. Christmas Dr Who = Weak too
    By HITFACTORY1403 in forum General Chat
    Last Post: 30th December 2011, 18:09
  2. Emission light on, engine sounds rough and is weak
    By sjgore in forum Engine & Drivetrain
    Last Post: 3rd January 2011, 15:32
  3. Spongey/weak brakes HELP!
    By sri andy in forum Suspension, Wheels & Brakes
    Last Post: 10th July 2009, 16:54
  4. Weak Radio Signal!
    By chrisschild in forum Electrical & ICE (including SatNav)
    Last Post: 16th March 2008, 17:58
  5. Weak at the knees
    By Spikey© in forum Vectra C / Signum Car Chat
    Last Post: 30th June 2006, 09:31
