Results 1 to 3 of 3
Thread: vectra c 1.9 8v adjusting notchy gear linkage ???
    leicester
    Default vectra c 1.9 8v adjusting notchy gear linkage ???
    been reading the posts re Notchy Gear Change... on the vectras, and a few members seem to agree that the linkage needs adjusting ???
    my car has covered 67k now so its probably ready for some tlc ,
    question is, does anyone know if the adjustment is a job that can be done yourself and how to do it ?
    thanks for any help or advice, lolly pop
    Regular Member big nath's Avatar
    Jan 2008
    Irthlingborough
    Look in the Haynes car manual it tells you how to do it in there , Just depends how brave you are , No special tools needed . It's like 2 wire cables from the gear stick to the gear box pull up the leather gear suround and you can see them ....If you mean that...
    Regular Member vec1975's Avatar
    West Midlands
    Had a really bad gear change from 2700 miles on the clock on my 06 facelift. My pre facelift was faultless. Facelift gear change has resulted in a new gearbox at sub 30k. Better now with 44k on clock but still definitely not the best
  1. notchy 2nd gear
    By eminemme42 in forum Engine & Drivetrain
    Last Post: 15th March 2012, 23:43
  2. Gear box oil changed and still notchy gears
    By dannycturbo in forum Engine & Drivetrain
    Last Post: 3rd September 2011, 19:26
  3. Notchy 3rd Gear Automatic
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 18:24
  4. Notchy Gear Change...
    By TheMoore in forum Engine & Drivetrain
    Last Post: 26th September 2007, 20:08
  5. Gear linkage cables
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 7th December 2006, 15:19
vectra c gear linkage problems
