Results 1 to 10 of 23
Thread: Rear tyres
    May 2008
    Middlesbrough
    Default Rear tyres
    Went to get my fronts balanced today and the guy was gonna change the backs for the fronts due to the amount of weight that needed to be put on, when he showed be my rear tyres both of them had plenty of tread on the middle and outside but the inside was warn down fully,
    He's told me that i should take it straight back to vauxhall and that my lease company wouldn't replace them until the cord was showing.
    Does anybody know what might be causing the tyres to go like this?
    IThis is on my 2.2 direct estate
    Regular Member garvey's Avatar
    Co Durham
    If you find out let me know as mine does it all the time
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    could it be cause by having a heavy load on the back all the time. im not sure im jst guessing realy.
    May 2008
    Middlesbrough
    its a 57 plate and i have done 31000 in it with not much more than a buggy or the weekly shop in, just don't like the fact that i still have to put up with bad balancing on the front because loys autolease said they were safe to use but the guy in ats said it was best not to use them tyres on the front
    Full Member Big Sig's Avatar
    Quote Originally Posted by stugga View Post
    They are illegal as soon as the tread is no longer visable so they have to change them before the cord is showing as thats just plain dangerous!
    (vecs are known for doing this sometimes as the camber etc can be adjusted on the back too)
    Regular Member Ben999's Avatar
    Milton keynes
    wheel camber I'd imagine.
    May 2008
    Middlesbrough
    I thought it was wrong too but i was there when the guy told loyds leasing and the guy on the other end was adamant that they won't replace them yet, i think i should kick up more of a stink , its my life after all
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    If you drive a car that is defective, due to excessive wear on the tyres (ie below the legal minimum) then it is not only your life, and the road users around you that is in danger, BUT it is also your licence that will get endorsed (as appropriate) and you paying the fines.
    I think a very strong phone call is necessary.
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    if you have tyres showing the cord you risk 3 points per tyre and upto £1000 per tyre fine,once the tread is gone that tyre is illeagal (you are allowed 1.6mm over 3/4s of the tyre width) but there should be visible tread on the last 1/4 of the tyre
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    oh, and get the camber checked too, along with the top links for wear....
  1. bulge on rear tyres...egg shaped??
    By marky2027 in forum Vectra C / Signum Car Chat
    Last Post: 16th September 2011, 20:34
  2. Rear Tyres worn
    By tangoman in forum Handling & Braking
    Last Post: 15th June 2011, 12:24
  3. To put new tyres on front or rear?
    By mickydoos in forum Handling & Braking
    Last Post: 7th June 2011, 08:08
  4. rear tyres wearing on inside
    By kirky2k4 in forum Vectra C / Signum Car Chat
    Last Post: 13th February 2011, 20:30
  5. New tyres front or rear ?
    By drewdrewuk in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2008, 20:18
vectra c tyres keep going egg shape
