Thread: car vibration
    Apr 2009
    essex
    Default car vibration
    Hi everyone, new to this owners club, joined after reading the excellent helpful advice given out by modest owners. I have a 2002 new shape 2.2 sri vectra(petrol) get a vibration/wobble feeling through the car only when accelerating..help req'd. Checked usual for signs of wear but nowt showing...bearings,rods are ok, new tyres all round with being balanced three times. Does feel as if its front end passenger side. Goes when foot is lifted off the accelerator pedal but back when applied on. Starts at around 40 mph. Driving me nutts now...thankyou in advance.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    My GSi did the same even with new tyres on. Came in at about 50mph under accelaeration and disappeared at 60ish. Then started to get a droning noise from front n/s and was diagnosed as a wheel bearing. Changed wheel bearing and shuddering problem went away.
    Modern style bearings on the front of Vec C's can't be checked by wobbling the wheel these days.
    HTH
    Regular Member barkzz's Avatar
    Could be wheel bearing, or a lose engine mount? Causiing vibration through the chasis
    Apr 2009
    essex
    thanks for your replies, i will have to investigate further into the bearings i think. Theres no droning or grumbling noises though.
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Quote Originally Posted by sxman1965 View Post
    When it does happen, it's an unmistakeable sound. Then you know it's time for a new bearing.
    Regular Member sidturbo's Avatar
    burnley
    just a thought but my brother has a vectra b v6 and his was doing this and it turned out to be a knackered drive shaft. hth
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    Wheel bearing sounds like a heavy vibration and will eventually disapear when you hit above 70 as the frequency will highten the pitch.
  1. vibration
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 11th April 2011, 07:32
  2. 2.2 sri vibration
    By lordreeson in forum Engine & Drivetrain
    Last Post: 27th October 2010, 19:44
  3. Vibration
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 20:46
  4. Vibration through car
    By Orbilator in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2008, 21:13
  5. vibration
    By Eddy R in forum Engine & Drivetrain
    Last Post: 20th August 2007, 19:59
