Thread: What oil for 2.2 dti
    Regular Member Middo's Avatar
    Swindon
    Default What oil for 2.2 dti
    Need to service the beast, what is the best oil to go for?
    tia
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    I use castrol edge 0w-30 although its a tad expensive
    Whatever you go for remember it holds a whole 5.5 litres
    Administrator plasma's Avatar
    On the Forum
    409 Post(s)
    Engine : 150
    Mileage : 74000
    I normally use 10/40 on my dti, change it every 10k though, think 0/30 or 5/30 may be too thin?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    It recomends 0-30 in the hand book as an alternative. Its long life and has the gm number on the bottle
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i use 10/40 in mine
    11 Post(s)
    See what Vauxhall recommend:
    http://www.vauxhall.co.uk/vaux/owner...do?method=view
    September 1995-2002 10W-40 ACEA A3 / B3
    2002 onwards 5W-30 ACEA A3 / B3 - ECOService GM-LL-A-025, GM-LL-B-025 - ECOService Flex
    2006 onwards 5W-30 GM-LL-A-025, GM-LL-B-025 - ECOService
    GM-LL-A-025 is for petrol engines.
    GM-LL-B-025 is for diesel engines.
    Apr 2009
    liverpool
    Default Oil..........
    I don't think you can go far wrong with the VX Specific Fully Synthetic 5w/30 from Halfords. If you are seriously wealthy then Mobil One is as good as you can get.Don't use a non fully synthetic, it could cause carbon build-up on some parts. It is also a good idea to clean out the engine by using Wynns or similar in the old oil for 10 minutes or so before draining, this also helps remove deposits, particularly in the ring lands.
    A Halfords Trade card is a great saver, the cost savings on stuff like bulbs has to be seen to be believed.
    Regular Member Darryl2.2DTI's Avatar
    Oct 2007
    Kilmarnock, Ayrshire
    Vehicle : Vauxhall Vectra C
    Trim : LS
    Engine : 2.2 DTI
    Mileage : 106000
    yup its the long life stuff in mine.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    Quote Originally Posted by the scouser View Post
    that is wery true. i bout nearly £100 worth of bulbs ( 4 bulbs in total) and it came in at just over £45, and a battery for 1.9TD peugeot and that was just over £40 and halfords had it priced at £95.
    11 Post(s)
    Have Halfords started stocking Vauxhall oils now?
