Thread: urgent......
    south shields
    Default urgent......
    travelling up to edinburgh airport today...got 70 mile into journey and a yellow oil light with wavey lines underneath came on dash....i pulled over and turned engine off, checked levels...all fine, restarted engine...light off and continued journey for another 70 miles to airport with no further problem...what was the light ??? cheers as i gotta travel back down when i get back!!!!
    Regular Member Pecojess's Avatar
    Nov 2007
    Aberdeenshire
    engine oil level m8
    The only ones with wavy lines underneath are :
    the coolant temperature / level warning
    This is quite common when the car has not been parked level overnight
    oil level warning
    If the sensor is near to failure it can come on briefly, either flashing erraticly or on permanently
    Nov 2007
    Aberdeenshire
    oil can with wavy lines: Engine oil level too low, check oil level top up if necessary
    the coolant one has a thermometer symbol with wavy lines underneath
    south shields
    checked level which was fine so u think a faulty sensor
    I've had this in a few diesel cars
    Each time I've stopped, checked the level and it has been between the min and max
    The car was booked in as "urgent" to ensure no engine damage
    In each case it was the oil pressure switch or sensor
    The light can also come on if the oil pressure is in error, even though the level is correct
    I've been advised that if the oil pump fails then this may sneek through, so continue to book in as "urgent"
  1. Urgent help with 2.0t .....I'm under it now
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 30th January 2011, 18:28
  2. Need urgent help
    By cbetts2005 in forum Engine & Drivetrain
    Last Post: 25th September 2009, 01:07
  3. Urgent help!
    By Kieran1981 in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2009, 19:17
  4. urgent
    By jones20002uk in forum Engine & Drivetrain
    Last Post: 21st April 2008, 17:10
  5. Urgent or not so urgent ?? Service Warning Light
    By martinh67 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2007, 09:54
