Thread: Juddering When Pulling Away??
    May 2008
    Ash Vale
    Default Juddering When Pulling Away??
    Hi
    My car has started juddering when pulling away in first, is this a clutch problem ??
    My car is a 07 plate vectra 1.8 sri with approx 29,000 miles. It has also just decided it needs a service.
    Does anybody know how much a service will be from VX and also what the juddering problem is?
    Mark
    Regular Member Sean-2.2Direct's Avatar
    Apr 2008
    Liverpool
    My girlfriends Corsa 07 plate does this as well does it more when cold that has 18k.
    I was thinking clutch as well
    May 2008
    Ash Vale
    Yes it is more when cold to be honest. I guess as its due for service I should book it in and get them to look at the juddering while its there and see what they say (
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Firstly, I don't know if you're aware that the service doesn't have to be done by VX without affecting manufacturers warranty?
    As long as genuine parts are used by a VAT registered garage to the published schedule, VX cannot refuse warranty claims.
    It sounds like the clutch has an issue. This almost certainly will be covered by warranty..
    Regular Member barkzz's Avatar
    Quote Originally Posted by MHowVECSRI07 View Post
    Hi
    Mark
    This has been a known issue on the 1.8's, and also the 1.6 Astra's.
    What your referring to is clutch judder, normally only happening in 1st gear, and once you get out of it, you no longer have the problem.
    It would be covered under warranty so I wouldnt worry too much. Only worry if they refuse to do anything with it, or try to say there is nothing wrong.
    You will find that if you get the clutch depressed to the correct point, with enough revs, yuo can avoid the "judder". Call it a sweet spot if you will
    May 2008
    Ash Vale
    Thanks for the replys
    Yes if you increase the revs abit then it does not judder so much but definately something is not right somewhere. I would imagine it would have to be covered under warranty Hopefully !
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Yep common fault on 1.8 vvt mate, VX know about it so let them know you know.
    May 2008
    Ash Vale
    Cheers Rushy will be on the phone to them in the morning
    Thanks to those who have replied to query
  1. Pulling to the right.
    By sriandy in forum Vectra C / Signum Car Chat
    Last Post: 29th July 2012, 23:41
  2. Car pulling to the right :(
    By !tf in forum Suspension, Wheels & Brakes
    Last Post: 5th December 2011, 19:18
  3. car pulling in 2nd
    By Morephun in forum Engine & Drivetrain
    Last Post: 18th February 2009, 02:12
  4. juddering when pulling off.
    By VEC-MAN in forum Vectra C / Signum Car Chat
    Last Post: 14th August 2008, 14:38
  5. Pulling Out Of The Pod...
    By Mark The Cabby in forum General Chat
    Last Post: 6th June 2006, 23:14
vectra juddering firsr
