Thread: Some more air con problems !
    Regular Member Kcs's Avatar
    Feb 2007
    Tamworth
    Default Some more air con problems !
    Hi all,
    What fuse or relay controls the Air con pump ?
    a friend at work has a 2006 1.8 sri that has zero air con function, the light on
    the button comes on, but the clutch or pulley part of the pump does not turn
    once the air con is activated, there is also no load on the engine !
    the outer pulley does however still turn freely by hand !
    Any idears would be very appreciated,
    Kcs
    Oct 2007
    LINCS
    hi its most likely lost its gas so it stops the compressor from coming on .
    Feb 2007
    Tamworth
    Quote Originally Posted by pidge View Post
    Cheers for that m8
    Regular Member Stevie-B's Avatar
    Mar 2007
    NI
    If it has 'leaked' gas I'd check all hose pipes as well.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Air con compressor won't engage if no gas pressure.
  1. z18xer vvti, problems, problems
    By gstore in forum Engine & Drivetrain
    Last Post: 20th April 2012, 13:33
  2. 1.8 vvti problems, problems problems!!!
    By gstore in forum Petrol Engine related
    Last Post: 3rd March 2012, 01:31
  3. crusie control problems, anyone had similar problems?
    By rozzer2006 in forum Engine & Drivetrain
    Last Post: 2nd October 2011, 21:20
  4. GSi problems
    By Piemyster in forum Engine & Drivetrain
    Last Post: 27th July 2011, 20:11
  5. 1.9 cdti auto problems problems
    By trigger in forum Engine & Drivetrain
    Last Post: 28th September 2009, 17:20
