Thread: help with noise
    wales
    Eek help with noise
    while driving lately i have noticed a slight grinding noise when turning left at low speed i initially put this down to a broken wheel bearing i am now starting to wonder as today i also heard a crunching sound ( its the offside front wheel) which is not the same sound as you get fron worn anti roll bar bushes any help would be appreciated...
    wales
    Regular Member JudgeApocalypse's Avatar
    Apr 2009
    Anglesey
    Hi, if your milage isn't high and your tracking and tire wear seem ok. Then it could just be a stone caught between your back plate and brake disc?
    wales
    thanks for the reply just to add milage 74000 new pads and discs on front
    Regular Member Bethan39's Avatar
    South Wales
    It wouldn't hurt to check your springs as well they can snap without you knowing, it probably isn't but worth a look!
    wales
    yeah i did give them a tug and they felt ok so not sure anyway the mot is due in june so i guess ill find out then , another bill to look forward too
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. noise
    By leighhockey in forum Vectra C / Signum Car Chat
    Last Post: 24th February 2012, 01:31
  3. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  4. noise
    By reeseandellie in forum Suspension, Wheels & Brakes
    Last Post: 2nd January 2010, 22:37
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
