Thread: Not hot air thru the blower!
    Apr 2009
    MERSEYSIDE
    Default Not hot air thru the blower!
    Hey, been having a problem with the heater / blower in my 54 plate Signum, 2.0 DTI,
    It has stopped blowing hot air through when i turn the heat dial up to hot.
    i only get cold air, or with the air con on, even colder air!
    its still blowing at all 4 different speeds, just no heat coming through.
    Anyone got any ideas about what this could be? or any ways to fix it?
    Jimmy
    Surrey
    Air mixer motor.
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    have you got pleanty of water in the expansion bottle if you have then it might be the mixer motor or dail
    Surrey
    Good point about the coolant tank level, you need that for warm air.
    Apr 2009
    MERSEYSIDE
    Yeah i've checked the level in the expansion bottle, its fine, guess its the mixer motor or dial then? any ideas about cost for that kind of thing?
    Regular Member wardy's Avatar
    Chichester
    yes, just ordered one for mine (seems to be fairly common problem) £79 not fitted
    Try to srip it down & clean all the cogs. Mine was finished so no option. Looks like about £2 worth TBH, bit of a rip off if you ask me.
    Apr 2009
    MERSEYSIDE
    where is the mixer motor? so i can have a look at mine and see how it is,
    cheers
    Jimmy
    Surrey
    £45 on Ebay. I have seen some 2nd hand ones on there for £20.
    http://cgi.ebay.co.uk/GO-NEW-CAR-PAR...3A1|240%3A1318
    Start by taking the glovebox out, it's on the right hand side from memory.
    Apr 2009
    MERSEYSIDE
    Default Heater sorted now!
    So i decided to give it a go myself, took the glovebox out, found the little beggar! its smaller than i thought.
    tried operating the heater controls to see if anything moved, and nothing happened.
    i managed to get the servo motor off, it helps to move the ducting out of the way by releasing the torx holding it in place too.
    Took it apart, and noticed that it looked like a tooth was missing on a cog, but i ralised that its supposed to be like that, as the range of movement means that it stops before it gets to that point, and mine had slipped so that it was stuck on the gap.
    Anyway, sprayed a little WD40, put it back together and plugged it back in, all working fine!
    Saved myself about £ 40 - 80 by having a go myself!
    Just need a code reader now to find out why i'm getting the car and spanner symbol up!
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    well done, its good when you manage to do it yourself. Top job.
  1. Blower
    By nokiaman1978 in forum Bodywork & Interior
    Last Post: 23rd April 2012, 22:43
  2. Need help with blower/fan
    By coogar in forum Bodywork & Interior
    Last Post: 31st January 2012, 16:52
  3. No hot air out of blower
    By dannycturbo in forum Vectra C / Signum Troubleshooting
    Last Post: 28th January 2012, 10:33
  4. Blower gsi 3.2
    By grabcol01 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 21:55
  5. blower
    By bakery in forum Electrical & ICE (including SatNav)
    Last Post: 27th December 2010, 15:18
