Results 1 to 10 of 14
Thread: lowering
    lanark
    5 Post(s)
    Vehicle : Insignia Elite Nav
    Year : 2012
    Mileage : 9k
    Default lowering
    am i right in thinking that the sri is 15mm lower than normal ?
    and is the sri 15mm lower than the standard elite because the ride height looks ok on the sri
    im looking to drop my elite by 30-35mm would that then give me the same ride height look as the sri or will i need to go lower ?
    Regular Member falco's Avatar
    Jun 2007
    Cockermouth
    An sri sits 15mm lower than the elite.
    If you lower your car 30-35mm it would be lower than the standard Sri.
    Regular Member Robbie69's Avatar
    as above mate.
    lanark
    5 Post(s)
    Year : 2012
    Mileage : 9k
    good so would a 30-35 mm droplook ok on an elite
    or anyone got a pic of an elite lowered 30-35 mm with 18" wheels on
    Jun 2007
    Cockermouth
    A pic of my sri dropped 35mm on eibachs, it's starting to settle in now so it's a little bit lower.
    If you are considering dropping 35mm some people advise the shorter dampers.
    It would be OK but I would go a bit lower, all depends what type of drop you want. Have a look at mine, I've dropped it 45/40, lowered it 30/25 ish.
    N. Ireland
    Also worth mentioning that if you lower, then fit bigger wheels (overall rolling radius) then they will raise the car up again! Of course the wheels will still leave less of a gap in the arch.
    So: (if my maths is right)
    -40mm lower
    + 40mm bigger wheels
    = 20mm lower body & -20mm gap in arch
    brum
    isnt it -60 gap in the arch as the wheel is now 20mm closer to the arch and the arch has been moved 40mm closer to the wheel
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    can you fit any lowering springs to an LS without changing the dampers???
    Sunny Dartmoor
    Yes,as long as its not more than 30mm,hth........
  1. Lowering on the sri.
    By Roy_Vec in forum Tuning
    Last Post: 13th September 2009, 09:15
  2. Lowering again
    By Ziggy in forum Handling & Braking
    Last Post: 2nd June 2009, 14:19
  3. Lowering
    By euro-dee in forum Vectra C / Signum Car Chat
    Last Post: 1st June 2009, 01:22
  4. Lowering
    By s1nglef1sh in forum Handling & Braking
    Last Post: 6th November 2008, 22:46
  5. lowering???
    By Lee.. in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2008, 23:49
