Results 1 to 10 of 17
Thread: 2.2DTi Won't Start - Immobiliser??
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Default 2.2DTi Won't Start - Immobiliser??
    Morning people!
    I've only owned my Vec C for two weeks now, and it start's ok each time no worries, then two days ago it spluttered into life and stalled. Then wouldn't have non of it, turns over really well as normal, but won't fire. I changed an "oily" looking leak off pipe (small section including t-piece over the third injector from the left) after reading about them and hoping it was that, then again it took forever but eventually started. Went for a burn to re-charge the battery mainly, then home. I used it on purpose 5 hours later, started perfectly like it should.
    So, used the bike for work yesterday so didn't touch the car till 10pm last night, again spluttered and stalled, then had none of it. The alarm has gone off a couple of times for no reason before this problem started. My mechanics coming out today to have a look, but over the phone suggests it maybe an immobiliser issue - what's the general feeling on this?
    Also - I bought the car privately so never got a handbook for the vehicle, I'm gonna get one off Ebay, but is there anything I should know about the alarm??
    Regular Member rayvo-gsi's Avatar
    warrington
    If there was a fault with the immobiliser the car wouldnt turn over at all as i found out myself.Also you would get the padlock symbol on your dash if it was an immobiliser fault.
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by rayvo-gsi View Post
    Ok, good to know thanks! So back to my air-lock idea then lol. See what the mechanic comes up with, he's ex-vauxhall anyway and reasonably priced, NO WAY would I go to the stealers...
    May 2006
    scotland
    Defective Glow Plugs??
    West
    I don't think the glow plugs will have any effect at this time of year, they only work around 5*c or below.
    It sounds to me like you either have air leaking into the fuel system or a faulty fuel pump.
    Is the engine mgt light showing at all? if so you might be best having the codes read.
    hth
    Apr 2009
    Stevenage, Herts
    hth
    Nope - engine management lights when i turn the ignition on, but goes out straight away when started - i'm taking that as normal. It does beep once when i turn the ignition on, but again guess that's a management check or something.
    I am suspecting a faulty pump or plain air leak somewhere else. Either way, bet it's not cheap!!
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    sounds like the cim might need tech 2ing, as the immobiliser runs from the cim,
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    It is not immobiliser, as it wouldn't even crank if this has activated, let alone run and stall.
    My old 2.0 DTi did this a few times, and was worse when parked 'nose up'. If it did this, I had to crank and crank for ages before it spluttered into life. Some white smoke would come out the tail pipe too - unburnt diesel and stinks.
    I would look again at ALL the leak off pipes and T pieces, and also check the security of the fuel filter housing seal. When did you last drain the filter of water?
    Administrator plasma's Avatar
    On the Forum
    367 Post(s)
    Engine : 150
    Mileage : 74000
    Run and stall is exactly the problem my veccy b is having for the past 2 days. Its one of 3 things for sure... starting with the cheapest...
    t-pieces and the rubber piping, including the pipe from the injectors back to the pump.
    injector seals - had this done on mine, but if they cheat and lift the camshaft instead of removing it then can pinch the new seal near cylinder number 1
    fuel pump seals - these can also let air in and last time i had one of these i sold the car!
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by Ste View Post
    The guy coming tonight to look serviced it two days after I bought it (two weeks ago) and changed the fuel filter then, maybe something there??
    I'll let you know what he comes up with...
  1. 2.2dti non start
    By andyrad29 in forum Engine & Drivetrain
    Last Post: 30th May 2012, 14:13
  2. Vectra 2.2dti wont start
    By jurisbrakis in forum Engine & Drivetrain
    Last Post: 15th November 2010, 11:32
  3. 2.2dti 03 Smoke on start up
    By alphabravo in forum Engine & Drivetrain
    Last Post: 6th July 2009, 10:14
  4. Help a 2.2DTi that won't start!
    By Celes in forum Engine & Drivetrain
    Last Post: 23rd March 2009, 18:10
  5. 2.2dti Squealing on start-up
    By tommy k in forum Engine & Drivetrain
    Last Post: 20th April 2008, 14:25
signum 2.2dti immobiliser fault
immobiliserfault vectrac 2.0 dti
opel vectra c 2.2 immobiliser
is there an immobilizer on the vectra c sxi 2.0 2005
vectra c immobiliser
how to bypass vectra c immobiliser
how to get round signam imobiliser
vauxhall frontera 2.2 dti immobiliser
vauxhall signum immobiliser problems
vectra Dti wont start says check
vauxhall frontera 2.2 dti starting problems
vauxhall ftontera dti imobilizer fault
