Thread: What causes Squeaky Brakes (Vec-B)
    Birmingham
    Default What causes Squeaky Brakes (Vec-B)
    Guy's,
    What on earth causes squeaky brakes?
    They are starting to do my head in as everytime I go near the pedal it sqeals and its annoying.
    Pads and discs are all OK and I changed the rear pads about 4 months ago so its all copper greased up properly.
    Its very very !!
    ANy tips on how I can stop it would be very much appreciated.
    Thanks.
    Bye bye Vec B
    - Hello Siggy!
    Edinburgh
    I think the copper grease can wear off sometimes so might need re-applied?
    WGAF#5
    i take it your only talking about light braking??
    if so the problem now comes from the matter of having no asbestos in the pads to lubricate them - so under light braking there is a resonance squeal of metal on metal - you could take your pads out and chamfer the edges this would give you a smaller surface area and the "stilletoe" effect would apply more pressure to a smaller surface area and this would help- the reason the noise comes on after a few weeks is because the pads are treated with a repellant to prevent premature wearing "for storage" you can reapply a similar product but it softens the pads and they wear quicker and when the "lube" dries up/is used the sqeal will return
    lots of manufacturers are having similar problems these days
    hth
    regards
    Dez
    Regular Member solorider's Avatar
    swindon
    Engine : 1.9 120bhp
    Mileage : 139,600
    cheap pads can cause this as well
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Copper grease on backs and sliders is needed.
    Birmingham
    hth
    regards
    Dez
    Yep, only under light brakeing. Thats quite an explanation, looks like I need to strip it down.
    Quote Originally Posted by solorider View Post
    The pads were from Vx stealers!
    Bye bye Vec B
    - Hello Siggy!
    Birmingham
    Quote Originally Posted by Ste View Post
    Will try this before stripping it all down !
    Bye bye Vec B
    - Hello Siggy!
    Somerset
    dirt can get behind the pads or between the pad face and the disc, i've had a small stone before imbedded in my pad. any dirt can cause the pad to be pressed to the disc uneven and under light braking, vibrate (squeel). hard braking the pad wont vibrate as it has too much pressure to hold it behind it. Just a quick strip down and clean methinks.
  1. squeaky brakes
    Last Post: 22nd June 2010, 13:19
  2. Squeaky Brakes
    By BENNYBED in forum Vectra C / Signum Car Chat
    Last Post: 23rd August 2008, 14:44
  3. Squeaky Brakes
    By smithi in forum Vectra C / Signum Car Chat
    Last Post: 30th July 2007, 15:03
  4. Squeaky Brakes??
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 12th July 2007, 15:49
  5. Squeaky Brakes
    By tj 666 in forum Vectra C / Signum Car Chat
    Last Post: 9th June 2007, 23:18
