Thread: rear brake light problem, bulb ok, please help
    Glasgow
    Default rear brake light problem, bulb ok, please help
    Hi There
    Noticed the bulb warning light on the display the other day and thought I'd take a look.
    Turned out to be the bottom brake light bulb on the drivers side. I took the bulb cluster out and inspected the bulb. It looked fine so plugged the connector back in and both lighs came on. The bottom one went over after a few seconds and no matter how much wiggling I did, it didnt come back on.
    I unplugged the connector and reinserted it again. The same thing happened. both bulbs lit then after a few seconds the bottom bulb went off leaving the top one lit.
    Does anyone have any idea why the car is doing this? I swapped some bulbs but still does the same thing.
    I'm really confused so looking for some direction.
    11 Post(s)
    The rear brake light should be the upper of the two rear side light bulbs. However when the upper bulb fails, the lower bulb takes over the role of tail/brake light.
    Here is a list of the bulbs from top to bottom.
    Turn signal light
    Tail light / brake light #
    Tail light
    Fog tail light (works on drivers side only - this is normal for the UK. You can use the passenger side one as a spare bulb for any of the other lights in either light cluster)
    Reversing light
    All bulbs are 21 watt single filament.
    # As previously mentioned, if the upper tail / brake light bulb fails, then the lower tail light then becomes the tail / brake light.
    Hunwick, County Durham.
    Trim : Elegance
    Engine : 2.0T
    Mileage : 59.4K,
    if the light is coming on for a small time and then going off, then i would say its an earth fault somewhere. but check what was mentioned about which bulbs are which, and change the bulbs with the ones on the other side to see if the fault moves.
    Glasgow
    Hi All
    Didnt realise both lights come on as tail lights. The rear left tail light had blown. New bulb in and now all working again.
    Thanks for your help
    Regular Member willoftoon's Avatar
    FOREST HALL NEWCASTLE ,,,,,OR DECKHAM ,, ON SUNDAYS .. DINNER TIME MAMMY,S
    I have this it has come on before then went off but today it is stayi g on but me brake lights are ok
    11 Post(s)
    Quote Originally Posted by willoftoon View Post
    Are you sure the brake lights are ok, or has the other side light taken over the role of brake light - see my post above.
    i just got wor lass to look haha so if i turn side lights on brake light should be off is that it so if it is out i will have 1 top brake light and 1 bottom
    right i have been out to car took holder out top bulbs are orange ,, yes ,, bulbs next 1 down under are normal but 1 on passenger side looks darker like it has blown but looks like filament is still intact but may be wrong but is def a differentcolour to other ,,darker as i said
    Full Member Big Sig's Avatar
    What? The side lights won't affets the brake lights comming on. Press the brake pedal and check that the exact same lamp on both sides is lit. RTFM
    haha sorry right ii have top bulbs they are orange ,, indicator yes
    next bulbs down are on well 1 is other looks darker ,, but filament is intact but may be loose ..
    next are sides i think
    anyway i have had them on with side and sides light i have tried darker bulb in other side but didnt work so i think it is bust off to get a new 1 now thanks for help if it works if it doesnt i take it back hahah acheers
    i have just walked about 5 mile for a bulb but all shops are shut haha i wont drive me car knowing i have dash light on i only drove home coz i had to
  1. Rear brake light bulb warning won't go off
    By tomo41 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd May 2012, 21:39
  2. what bulb for brake light?
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 26th August 2011, 00:56
  3. Brake bulb warning light
    By SeeDeeXeye in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2009, 02:42
  4. Brake bulb warning light
    By steve1975l in forum Electrical & ICE (including SatNav)
    Last Post: 28th June 2008, 19:11
  5. New brake light bulb
    By prm in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2006, 08:00
vectra rear brake llight lights up on side lights
brake light out vauxhall vectra
one vauxhall vectra brakelight not working all other lights working
vectra c break light issue
vauxhall vectra brake light fault
opel vectra bulb light but lights all working
vectra brake light system how it works
vectra c brake light not working
vauxhall signum rear light problems
vauxhall vectra rear light problems
2008 vectra light problems
turn signal not working but bulb is good vectrac
vauxhall zafira tail light not but brake light does
brake light vectra 2009
vauxhall vectra side and brake light on together
vectra c rear light bulb cluster
https:www.vectra-c.comforumshowthread.php79031-rear-brake-light-problem-bulb-ok-please-help
bulb blown filament still intact
vauxhall corsa rear bulb is out but comes back on with a slsp
help with vauxhall vectra lights issue
vectra brake light has come on
56 vectra brake light bulbs which filament
vauxhall vectra 2005 taillight troubleshooting
how many brake bulbs on vectra c
vectra tail light problem
