Thread: Glove Box removal
    Regular Member greeningr's Avatar
    Jan 2006
    Oswestry
    Default Glove Box removal
    I'm sure one of you can help here.
    How do I remove the glove box to see if I have the prewiring in place for a mobile phone?
    I'm having a nokia carkit installed by work and I just want to know if the prewiring is present in the vectra.
    Regular Member OilBurner's Avatar
    Feb 2006
    Bromsgrove
    Easy. You just need to get at all the Torx screws around the glovebox.
    First, remove the ones visible below the glovebox. Then, open the glovebox and remove the ones visible under the opening.
    Don't forget to detach the light otherwise it will pop out with the glovebox and possibly damage the wire.
    Once unscrewed, the whole lot just drops out of place by hand.
    HTH!
    Jan 2006
    Oswestry
    Thanks Pete
    SOUTH SHIELDS
    6 screws in total 3 top 3 bottom
    Regular Member Ben H's Avatar
    Herts\Beds Border
    If you haven't got the phone loom there an aftermarket audio lead can be fitted to still route the audio through the stereo, infact I made one the other day using 3 wires & 2 pins from an old VW lead. Aterwards I realised I could of done it without using pins but much safer using them.
  1. Glove box
    By Garfo in forum Styling
    Last Post: 30th June 2011, 23:02
  2. Glove box
    By tubby in forum Bodywork & Interior
    Last Post: 17th May 2011, 21:13
  3. glove box
    By rave5 in forum Bodywork & Interior
    Last Post: 31st January 2010, 18:47
  4. Glove Box Removal
    By AirCooledHeaven in forum Bodywork & Interior
    Last Post: 31st August 2008, 11:45
  5. Glove Box
    By barney in forum Vectra C / Signum Car Chat
    Last Post: 8th November 2005, 00:05
remove glove box vectra c
glove box uninstallation opel vectra c
how to remove vectra c glove box
