Results 1 to 10 of 15
Thread: 'V' removal help
    Regular Member Bullylad's Avatar
    Bolton
    Default 'V' removal help
    I had a look at removing the chrome V on the front of the car.
    I started by removing the 4 torx screws (2 on each side) of the black cover that is revealed when the bonnet is lifted.
    I expected this cover to be easily removed allowing access to the 'V' so i could remove it. But turns out it's not that simple.
    Having removed the screws it allowed limited access with a screw driver to the clips behind. When i tried to release the clips the black part underneath the silver part (pic 2) broke.
    How many clips are there holding this thing on and is there an easier way of removing it?
    HELP!!
    Winteringham
    Don't know if it helps but when I replaced my grill with an Irmy one I had to remove the bumber
    Regular Member glynn's Avatar
    stevenage, hertfordshire
    i thought you could just pull them forward
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    hello mate
    start car up turn wheels full lock and you will see 2 torx screws under wheel arch remove these (both sides)
    then being very carefull and take your time, push bumper towards front of car and pull towards you at the same time
    as i say dont force too hard as there are only plastic lugs holding it on, do this both sides
    this will then allow you to pull bumper down giving more access to it
    there is a link on here somewhere to show you in more detail
    Regular Member Bethan39's Avatar
    South Wales
    I did mine last week found it easier to remove the bumper there are 4 push fittings under the bumper holding the undertray on it's not an easy job!
    Bolton
    Thanks for the help guys.
    Got diverted (told to by the Mrs) to sort out a couple of jobs in the garden instead of messing around with that flaming car.
    IF it's fine tomorrow I'll give it another go and see if i can get a mate to give me a hand?
    Hopefully i won't **** it up
    Regular Member Craig1985's Avatar
    harwich essex
    i got hack off in the end and ripped it off breaking the chrome clips, but only because i had a nice new painted one.
    Have fun .......
    Regular Member WKD-mcc's Avatar
    glenrothes
    a done what you done so far,removed the for screws holdin the top of the bumper.then all i done was pull the top of the bumper out with one hand and with the other,went round all the clips with a screw driver and pushed them all free then managed to wedge the v out with the driver after that,bit rough but got the job done.painted mine over the weekend just passed there.another way of doing it is to take the bumper right off like others have said.
    Bolton
    When i started going around the clips (the ones i could reach) with a screw driver, the silver part remained intact and the smaller black piece underneath seemed to break.
    I am assuming that i need to keep the black part in tact so that when the grill goes back on these will keep it in place?
    South Wales
    Yeah the black part is the top grill which the chrome V clips onto hth
  1. dpf removal
    By chrislloydie in forum Vectra C / Signum Car Chat
    Last Post: 6th January 2013, 10:53
  2. Tar removal
    By Jim Bob in forum Detailing and Car Care Discussion
    Last Post: 17th April 2010, 20:18
  3. Cat removal & EGR
    By Bullylad in forum Vectra C / Signum Car Chat
    Last Post: 25th September 2009, 16:58
  4. DPF removal
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 16th March 2009, 17:01
  5. Tow Bar Removal
    By korlinski in forum Bodywork & Interior
    Last Post: 30th April 2007, 21:19
