Thread: Auto Box - Jumping and missing gears
    CUMBRIA
    Default Auto Box - Jumping and missing gears
    Hi Guys
    Right this problem has just started when the car is on a long run and as you might expect an automatic box would have a smooth gear change. But no its seams to be jumping or like a surge when coming from a standing start as it is the worse from the standing start. But on the motorway as will it still Jumps Like I say not a smooth Change.
    It actually seams thatís it missing the gear and then engaging once the computer realises it hasnít fully engaged the automatic box making it not a smooth transition when accelerating. As when it is cold it doesnít do it now hopefully is just a sensor that has gone T$Ts up and not the gear box.
    Any help would be appreciated or suggestions to why that is happening
    Vauxhall Signum
    3.0 CDTI V6 Elite
    Automatic Box
    89k on the clock
    Regards
    Simon
    Winteringham
    Mine was doing the same a update of the software Via Tech 2 fixed the problem for me
    CUMBRIA
    How much did the tech 2 update cost you to do?
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    Engine : 140 Ecoflex S/S
    First thing I'd check, and it's free, is the fluid level.
    Has the oil ever been changed? VX recommend every 40k miles so yours should be on it's second change.
    HTH
    CUMBRIA
    Not sure only bought it 4 months ago.
    is it easy job or do you need a car lift?
    Winteringham
    Quote Originally Posted by simsr4 View Post
    got it done when I had bluetooth fitted on Saturday
    Carmarthen
    Vehicle : Insignia
    Trim : Sri
    No lift required, just a trolley jack and stand to get to drain plug and then fill through engine bay. Did mine with the use of Haynes manual. Although the haynes doesn't cover the 3.2V6 petrol or 3.0CDTi, it does cover the AF33 gear box which I believe yours is. Total cost for 4lt of fluid will be about £30 (from Parts for Saabs http://www.partsforsaabs.com/product...oducts_id=3454) and 2 hours of your time. Most of this time is topping up the fluid and road tests to get the level spot on.
    Apr 2009
    bromley
    Simsr4, did you manage to sort out the problem, As my car is doing exactly the same thing. Ive only had the car for three weeks.
    CUMBRIA
    yeah i changed the oil levels and it seams to have stopped it.
  1. Replies: 1
    Last Post: 9th April 2009, 20:03
  2. Auto box - total loss of gears
    By iddamsel in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 15:03
  3. 3.2 auto jerking when changing gears
    By j13hdb in forum Engine & Drivetrain
    Last Post: 8th February 2007, 12:54
  4. Jumping on the bed
    By Spikey© in forum Comedy & Humour
    Last Post: 24th March 2006, 00:19
  5. Jumping cars
    By Graeme in forum Comedy & Humour
    Last Post: 2nd January 2006, 19:38
insignia auto jumps on gear change
vauxhall automatic missing a gear
