Results 1 to 10 of 29
Thread: Wing mirrors working together?
    Regular Member s0501291's Avatar
    Warrington
    Default Wing mirrors working together?
    Hi
    I've herd that on some Vec C's both wing mirrors adjust at the same time, is this a case of, your car either has it or not? or is it somthing that can be turned on and off?
    Any info welcomed
    Pete
    It changed on the later models to that way. I think you can change it to the previous type (i.e. each button only alters that mirror) but would involve a Tech 2 session.
    Regular Member mattolly86's Avatar
    oxfordshire
    and it is really annoying
    Regular Member Avenged's Avatar
    Liverpool
    i have an 07 vec.. and if i have the button on the drivers mirror... both move, but if i have it set on the passengers mirror only the pass mirror moves!
    HTH
    West London
    same as above in my 05 club
    Regular Member solorider's Avatar
    swindon
    Vehicle : Insignia
    Engine : 2.0cdti 160bhp
    Year : 2010
    Mileage : 92274
    Quote Originally Posted by Avenged View Post
    HTH
    correct,you adjust the drivers side to yourself,then you adjust the passenger side,so once set in theory if someone else drives the car they only need to adjust the drivers side,the passenger side should be in the right position
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    When you get used to it, you will se what a good idea it is.
    Plymouth
    It came in on the 54 plates!!
    U choose the drivers side and it moves the passenger side too!!! Damn annoying!
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Quote Originally Posted by Diet1985 View Post
    No it didn't. My 04 has it for sure. I thought it was standard from the start.
    Winteringham
    Had it turned of on mine on Saturday when I had a Tech 2 sesion on the car
  1. wing mirrors
    By cookiejar31 in forum Styling
    Last Post: 25th January 2009, 22:59
  2. Wing mirrors
    By mspvxr in forum Vectra C / Signum Car Chat
    Last Post: 17th July 2008, 08:55
  3. wing mirrors
    By simon5800 in forum Vectra C / Signum Car Chat
    Last Post: 11th August 2007, 01:52
both wing mirrors moving at the same time on a vectra c 2007
both wing mirriors moving at the sam time on a vectra c 2007
vectra both side mirror adjust
