Thread: park pilot wont work
    Wirral / ellesmere port
    12 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    Default park pilot wont work
    recently after replacing my front bumper on the zafira i had to get az new
    bumper harness and park pilot sensors to fit onto the new facelfit bumper,all
    fitted and now the system wont work,ive repalaced the origional bumper
    with the origional sensors and harness and again it wont work although it
    did before i replaced the front bumper,ive checked the fuse etc but all ok,i
    had it to me m8`s yesterday for tech2 and no faults or error codes were
    found,the harness plug for both bumpers for park pilot are identical,the
    foglamp harness is also incorporated with park pilot harness but the
    foglamps on both bumpers work perfectly but i really cant understand why
    the park pilot system aint working,ive also checked for damage on the new
    harness but the old one will not work neither.
    the rears wont work as due to the fault as its all inter linked,the battery
    doesnt need dis-connecting as i done the signum same way,control box
    can`t be faulty as it was working ok before i removed the old bumper etc
    all im getting is a bleep sound from park pilot everytime i put the car in
    reverse and the warning light comes on and the switch lights up,ive dis
    connected thr front sensors and fully re installed them but still the same.
    im so annoyed over this as all ive done is changed the front bumper to the
    new style and this happens.
    anyone have any suggestions ????
    Oct 2006
    Wellingborough
    I think from the description one of your sensors is getting a false "there's something right in front of me!" reading. this could be from too thick paint, or dirt on the sensor, particularly between the disc and ring pieces.
    12 Post(s)
    Trim : elite
    Year : 2011
    hmmm dont think so as the original park sensors in old bumper still has same problem
    Oct 2006
    Wellingborough
    Hmm, yes. sounds as though it must be a short somewhere in the loom then. are the front sensors connected to the module by the REC or is there a module under the bonnet?
    12 Post(s)
    Trim : elite
    Year : 2011
    Quote Originally Posted by Flaninacupboard View Post
    the control module is in the rear rec,the harness plugs together behind the
    front bumper as thats were ive only un plugged it from and then re
    connected the new harness on the new bumper to,ive only purely touched
    the front bumper.
    really cant understand that the old sensors or new sensors don`t work.
    but however the fogs on the old bumper work fine aswell as the new fogs
    in new bumper
    Oct 2006
    Wellingborough
    All i can suggest is bumper off and inspect/reseat the harness. may also be worth checking there's no short between the front harness and REC.
  1. Park Pilot
    By BigWilko in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2012, 22:39
  2. Is everything here for Park Pilot?
    By John LE in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2012, 21:19
  3. Park pilot alert but I don't have Park Pilot
    By krisby in forum Vectra C / Signum Troubleshooting
    Last Post: 21st November 2011, 10:58
  4. Nearly there! (with park pilot)
    Last Post: 29th August 2009, 08:58
