Results 1 to 10 of 28
Thread: Help please...
    Regular Member JudgeApocalypse's Avatar
    Apr 2009
    Anglesey
    Default Help please...
    Hello everyone I'm a newbie to this site, it looks like there are people here with good technical knowledge of all things vauxhall? This could be a good thing as I'm a little bit stuck!
    My car is a just recently acquired siggy 2.2 Dti 04 plate. Now then, looking from the front of the car, down on the right hand side between the engine and the base of the battery box there is a little solenoid looking gizmo thingy.
    It has two nipple things (oo, err!) problem is some time in the previous, a gremlin, evil pixie or nupty has removed all vacuum pipes from this solenoid thing.
    Can any kind soul out there with a 2.2 dti, have a look under their bonnet and let me Know what should be attached to the top and bottom nipps and where these pipes of infinite mystery go to???
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    pics would help bud
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above with the pics please
    and still loving it
    Apr 2009
    Anglesey
    Hello, thanks for the quick replies, hope this pic helps?
    Engine : 2.0DTi
    Mileage : 73350
    To be honest mate i cannot make head nore tail of that pic , can you take some of the engine bay but not as close as this one , because these system,s vary quite a lot and the solenoids are often mounted in different places depending on where the car was manufactured.
    and still loving it
    Apr 2009
    Anglesey
    Ok will do, your right about the location thing. Haynes manual 4618 for the 2.0 has the turbo wastgate solenoid on the left hand of the engine bay above the air box. page 4B.9 pic 10.55 if you have the good book of confusion to hand. mine is cliped on to the side of the battery tray steel not far from the vacuum pump!
    Apr 2009
    Anglesey
    Here are some more pics, if anyone can help with the;
    where does the tubing come and go to quiz...
    Engine : 2.0DTi
    Mileage : 73350
    Quote Originally Posted by JudgeApocalypse View Post
    Hi mate you should have a vacuum hose running from your turbo to your solenoid connects into the bent rubber hose in the pic .
    now you should also have a hose from the vacuum unit itself ( the round unit on the right hand end of your cam shaft housing ), to the solenoid via a tee piece which loops off to the other solenoids .which in turn fed your boost sensor and the egr valve
    hope this helps regards bob
    and still loving it
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Any tubes hanging around not connected. Any issues with the car?
    Apr 2009
    Anglesey
    Hi, no unconected tubes and thats what was so confusing. I think that pics would be of great use as It sounds a little complicated, many thanks to you all for your help in this matter.
