Thread: replacemenr key parts
    Apr 2009
    dundee
    Default replacemenr key parts
    Hi the key fob part of my key is wearing away, is there any way of replacing thr rubberised parts of the key (54 vectra c 2.0ltr diesel)
    Worth a look on dbay need to check 2 or 3 button hth ........
    Apr 2009
    dundee
    i had a look on ebay for these parts, all there is is two button fobs, i have 3 button fob, anywhere else i could look for the replacement parts?
    Sunny Dartmoor
    The dealers do them........
    You require a new key from the dealer try the search try this for a start hth .. http://www.vectra-c.com/forum/showth...highlight=flip
    They come up sometimes swap your bits over maybe
    http://cgi.ebay.co.uk/VAUXHALL-3-BUT...1%7C240%3A1318
    Apr 2009
    england
    you can order a new key from the main stealer just use the key number on the car pass and you will get a new flip key as they no longer sell the old fixed type key trade price is about £45 (retail is about £120 +) but they will charge upwards of £25 to code the key to your car (unless you do it yourself with cop-com software or similar
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Regular Member Cyruskint's Avatar
    Jun 2009
    Dorset
    Default Key & Fob
    I have just purchased a key with chip & a 3 button fob from separate Ebay sources.............can I get Vx stealers to reprogram (original 2nd key misplaced, so can't swop blades over)?
    Jun 2009
    Dorset
    Default Key parts
    sobering lesson.......... only £6 to cut new blade at locksmith, then down to Vx dealer to Tech 2.................. first, wouldn't prog as new blade has chip, but mine doesnt. Mechanic kindly riped said chip out. Try again........ failed again & again...........mechanic suspects that the 3 button fob is from an Omega or other model, and this wont compute......... changed new blade onto old fob - no problem, so must be new fob......... now have to try & get refund from ebay dealer
    Now, does anyone know different?
    Does anyone have an underbonnet fuse box, prob from a 54/05 plate Sig or Vec with upmarket spec. Part No. 93184292 Code "EF" ??
    This is for my 05 Siggy.
    11 Post(s)
    Pretty sure it's been mentioned on here before if the replacement fob is 2nd hand and previously programmed, then it can't be programmed to another car.
  1. xp2 parts on car parts connexions
    By kdadidog in forum Styling
    Last Post: 3rd August 2011, 18:36
  2. OEM Parts VS Third party parts
    By suj786 in forum Vectra C / Signum Car Chat
    Last Post: 12th June 2006, 07:30
