Results 1 to 10 of 11
Thread: Location of boost valve
    east yorks
    Default Location of boost valve
    I am wanting to clean the boost valve on my 56 plate 150 cdti. Can anyone advice as to its location and how to remove and clean.
    Any pics would really help.
    Many Thanks
    Regular Member Grimo72's Avatar
    Apr 2008
    Lincs
    hello mate
    pull off the plastic covering on engine
    look to the back right, you will see the EGR valve
    move to the left and you will see a little black unit about 2" square held on with one tork screw thats it the boost sensor
    i will find a piccy for you bear with me
    east yorks
    Your a star thanks. Without wanting to sound stupid then what is it i am actually cleaning? Does it pull apart, or is it just a connection i am cleaning?
    Apr 2008
    Lincs
    Quote Originally Posted by broadgates View Post
    not a stupid question, what you do is unscrew the bolt, pull off the connector, and the pull the sensor towards the windscreen whilst rotating it
    and it will just pop out, you will see a little cage with a piece of metal that looks like a piece of rice (sorry thats about as technical as i get)
    you need to clean with something electrical contact cleaner to remove all kak round it, be very carefull with it though quite fragile
    Apr 2008
    Lincs
    Apr 2008
    Lincs
    or if you get stuck, come for a trip over to gainsborough and ill help ya with it
    east yorks
    well all done. Gave it a spray with carb cleaner but it didnt actually seem that bad. Better to do it know though i thought as opposed waiting until it really needed doing.
    Thanks for all the replies.
    Regular Member Ste's Avatar
    ..... Driving the Jaguar XF
    Vehicle : Jaguar XF 3.0D V6
    Trim : Black
    Engine : 3.0D V6
    Year : 0000
    Gainsborough, I used to work there at Eminox....
    Apr 2008
    Lincs
    did you clean the egr valve i did mine and it was almost blocked with kak
    Apr 2008
    Lincs
    Quote Originally Posted by Ste View Post
    small world isnt it, they are not doing to well in current climate just made a few redundancys
  1. egr and boost sensor location (with pic)
    By frasedeb in forum Engine & Drivetrain
    Last Post: 21st May 2012, 21:04
  2. Egr valve location
    By irmscher-brett in forum Engine & Drivetrain
    Last Post: 10th February 2011, 11:56
  3. boost sensor location?
    By chowwie in forum Engine & Drivetrain
    Last Post: 30th September 2010, 08:00
  4. pressure boost location.
    By leeson in forum Diesel Engine related
    Last Post: 18th September 2010, 21:29
