Thread: aftermarket HU question
    Regular Member darko2301's Avatar
    Croatia
    Default aftermarket HU question
    i have been thinking about new HU for quite a long time by now, but the only problem is that i want to have steering wheel controls and i want the device to turn on/off with ignition like the radio which i have now..
    kenwood does adapters for steering wheel controls so i think it will be my first choice. however, today while i was reading fitting instructions i got to this warning:
    "These Opel vehicles do not feature a 12v ignition feed to the Head-Unit. The replacement unit will need to be manually turned off (or face panel removed) when the user exits the vehicle. If desired an ignition input can be added by disconnecting the bullet connector on the red wire (Harness A) and adding a flying lead to take this to a true ignition feed (Normally located at the Ignition barrel or fuse box)."
    So, does this mean that it wont turn on/off with ignition? Are the steps mentioned above complicated to do because i'm a total beginner and I won't be fitting it anyway..
    Is there any chance to get it working with ignition?
    Regular Member m3ath3ad's Avatar
    Aug 2007
    Minehead
    by the sounds of it yeah mate..... i had a jvc dvd player in mine and had to have to switch it on and off manually
    Blantyre
    Quote Originally Posted by m3ath3ad View Post
    Wrong mate, I have mine wired to the cig lighter and the stereo only comes on when ignition is on, its not a permanent live
    Croatia
    so it turns on and off with ignition? that sounds like a simple solution to me?
    the only problem is that it would never work without ignition though..
    Regular Member Bethan39's Avatar
    South Wales
    Mine is a facelift with a Jvc hu with the quadlock adapter autoleads steering wheel controls not wired up to cigarette lighter just the ordinary wiring and it only works with the ignition turned on so it is possible!
  1. Aftermarket Stereo wiring question
    By elle2801 in forum Vectra C / Signum Car Chat
    Last Post: 16th December 2017, 20:18
  2. Help fitting double din head unit... aftermarket cage question?
    By Deann in forum Electrical & ICE (including SatNav)
    Last Post: 17th September 2011, 10:23
  3. aftermarket HU
    By Dippy-Vx-line Red in forum Electrical & ICE (including SatNav)
    Last Post: 9th September 2008, 16:12
  4. Wiring Question for Aftermarket Headunit??
    By Cilldara1 in forum Electrical & ICE (including SatNav)
    Last Post: 30th June 2007, 21:21
  5. aftermarket HU
    By chris_20 in forum Electrical & ICE (including SatNav)
    Last Post: 22nd August 2006, 18:42
