Results 1 to 10 of 14
Thread: Water "swishing" noise
    Regular Member CDXI_2003_AUS's Avatar
    Melbourne, Australia
    Default Water "swishing" noise
    Just wondering if anyone else has had the same water"swishing" around noise. Trying to figure out what it is, really bugging me. Every thime i go around a corner i can hear water moving around.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Quote Originally Posted by CDXI_2003_AUS View Post
    Let me guess sounds like its coming from behind the dash board? Think it is actually under the skuttle where the linkages are, there are drains there thinkg the water sits there. Only notice it after a heavy down pour or during one.
    Gazza4
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    That's the exact noise i'm hearing. Car has been sitting around for a while as i got a VXR as a company car. Hoping that your right as the damn thing is loosing coolant and was hoping that noise wasn't a result of that. Mind you, never heard it when I drove her every day and still had the coolant loss problem.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Coolant loss may be Cylinder head m8 - i hope not, check the oil too - if this is dropping rapidly then the head gasket is on its way out.
    Take the car to a garage and get them to do a pressure test.
    Gazza4
    Gazza4
    Oil is still looking good thank god
    It only looses coolant when I run the A/C. I have it turned off, but the missus loves the A/C to much and thats when I run into problems.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I would still get it pressure tested, the possiblity of a cylinder head issues is not eliminated tho m8, oil is ok then there is less likely of a head issue but I would deffo get it checked.
    Gazza4
    Gazza4
    I hope it isn't that, only had the major service a little while ago. I have the pressure test kit in my garrage so can check it pretty easily.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    better safe than sorry bud.
    Gazza4
    Regular Member djr69uk's Avatar
    Midlands
    could be head gasket or possibly a coolant leak from one of the hoses?
    Quote Originally Posted by djr69uk View Post
    Please be a hose
  1. loud "thunk" noise from passenger side suspension
    By Gordon Livsey in forum Suspension, Wheels & Brakes
    Last Post: 10th October 2010, 15:14
  2. "clunk" noise when taking foot off brakes
    By sdnatlst in forum Handling & Braking
    Last Post: 21st May 2010, 19:13
  3. Odd "Water Noise"
    By Redviper in forum Bodywork & Interior
    Last Post: 24th September 2009, 20:59
  4. 1.9cdti - high idle speed and new "noise"
    By mossie in forum Engine & Drivetrain
    Last Post: 7th October 2008, 16:12
  5. Vectra 2.2dti "grumbling/knocking" noise
    By Peetoki in forum Engine & Drivetrain
    Last Post: 17th February 2008, 14:51
